CEL P2628- Rear Upsteam A/F Sensor Help
I pulled P2628 and I need some help. The first shop I called told me the sensor was $203. Then I called autozone and they told me the Bosch version was $90 (http://www.autozone.com/autozone/par...er=491525_0_0_). Do they do they same thing?
Secondly, I need to make sure I have the right location for this. Looking at the service manual it isn't very clear what size of the engine the diagram is showing.
![Name: 425963735_photobucket_35392_.jpg
Size: 64.1 KB](https://acurazine.com/forums/attachments/3g-tl-problems-fixes-114/52955d1501293851-cel-p2628-rear-upsteam-f-sensor-help-425963735_photobucket_35392_.jpg)
Is this the one right in the very front? I know it's called Rear Upstream but I don't see any others around. Considering my plug goes off to the right, I think I'm out of luck. If it's literally in the back of the engine, I have no idea how I'll get back there to get at it.
425963735_photobucket_35393_.jpg?t=1296423727
firewall
123
456
radiator
It's the top, rear sensor, part #36531-RCA-A02, $118 for OEM. You can reach it. Removing the tower strut bar will make it much easier.
part #9 in the diagram:
http://www.acurapartswarehouse.com/P...gPicture=False
The Bosch wide band o2 sensor should work as well.
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Perfect answer. Thanks. Hopefully removing that bar wont be too hard. Ill take a look tomorrow. Im hoping this swap will also help my mpg a bit. Its been worse than usual lately.
The bar is easy: 3 nuts on each end, 2 small bolts on the driver's side, 1 small bolt on the passenger side. Retorque the nuts to 21 ft/lbs.
Well this seemed easy until I started doing it. 2 of the bar bolts came off easy but the other four stripped almost instantly since they are soft brass. I decided I could get at it without removing the bar.
First I need to figure out how to get the existing pigtail clip off. There seems to be a tab i can press down, but even doing so the pigtail doesn't move. What's the trick?
425963735_photobucket_36566_.jpg?t=1296947000
Then once I can get that I just got to hope that the sensor isn't stuck on as hard as past sensors. I'm going on three hours now so any help would be appreciated.
For the connector, press on the end of the tab (indicated by arrow) and pull. Sometime you have to really the end hard while pressing the tab and pulling.
![](http://i263.photobucket.com/albums/ii154/jmillerl/O2sensorplug.jpg)
Question regarding P2628 error code
Hi,
I have P2628 for a while, it has been on and off for half a year. Other than the check engine light is on, I haven't noticed any different feel of the driving.
What's the problem ? It's the faulty sensor I need to replace or it really reports something I need to take care of?
I searched the forum and found the thread and I wonder what's the result after replacement of the sensor?
Thanks a lot and looking forward to hearing from you guys!
Pw123
Pw123
Hi,
Pw123
Pw123
P2628-Rear A/F Sensor (Bank1, Sensor1) LABEL Circuit High Voltage.
It's most likely a bad sensor, but could also be a bad connection.
You really should get it fixed. You don't want your engine running with a bad sensor sending erroneous information to the ECU. You could wind up with poor gas mileage, fouled plugs, burned valves, etc.
Here is a DIY thread on how to replace the sensor:
https://acurazine.com/forums/3g-tl-problems-fixes-114/e-130-diy-oxygen-o2-sensor-installation-rear-upstream-f-aka-p2251-811823/
J1simon (04-01-2012)
Thanks!
Hi,
Thanks for the quick reply. I will try to fix it soon, hopefully by following DIY instructions you pointed. It seems to me a doable job for me.
Pw123
Pw123
I replied to your PM, but it says your quota has been exceeded...
https://acurazine.com/forums/showthread.php?t=811823
mada51589
05-03-2022 08:54 PM
Billu99tl
09-13-2015 11:30 AM
