Car wouldn't go in gear
Old Mar 6, 2012 | 12:49 PM
prarce2's Avatar
I have a 2005 mt and was driving to work yesterday we had heavy rains here in Hawaii so have way to work I was caught in a flood water up to the license plate I push through cause I could not turn around. I made it but as I got to the parking lot at work the car started to sputter I parked in a spot waited 5 minutes restarted it. It started fine moved fine I parked it again. About 8 hrs later I went to go home and the car would not go into gear. If the car was off it would move in and out of gear when I turned the car on no go. I slammed it in reverse and has worked fine since. Does anyone have an idea why this would happen or should I worry about this? Any help plz
Old Mar 6, 2012 | 01:12 PM
johnny3's Avatar
The clutch probably got soaked & was not releasing, that would not let you put it into gear while engine was running. You need to have it inspected up on a rack & drain transmission/replace transmission oil.
Old Mar 7, 2012 | 12:06 AM
prarce2's Avatar
thanks for the help
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
asianspec
Cameras & Photography
34
Nov 4, 2019 11:11 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
Mike Bertram
Sep 10, 2015 09:27 AM
