Car wont start up
Old Jul 4, 2018 | 02:42 PM
Deyton Flores's Avatar
Car wont start up
I recently crashed my 04 TL. The only damages on the car is the front bumper and any parts that are directly behind it. When i put in the key all electronics work perfectly fine. My question is what could have been damaged preventing my car to start.
Old Jul 4, 2018 | 06:29 PM
Will Y.'s Avatar
Registered but harmless
Does the starter work, or turn when you turn on the ignition?
If not, look at the starter's ground wire to see if it is connected; then hit the starter casing with a breaker bar or metal bar to see if the starter will turn.
Report back once you've done that.
Old Jul 6, 2018 | 08:02 AM
frankjnjr's Avatar
Any luck, getting it started. Since the battery, is in a vulnerable position, I would double check the cables. A loose, or corroded cable, could create the symptom, you describe.
Old Jul 15, 2018 | 01:08 PM
Chad05TL's Avatar
airbag sensor is behind the front bumper. I think there are 2. But I can't remember for sure , 1 or 2.
Roblee23
Aug 22, 2018 08:14 PM
syn11
Feb 22, 2018 01:31 PM
jzebrook
1G TL Problems & Fixes
Apr 16, 2011 08:11 PM
BENDER08
Apr 13, 2009 08:09 PM
soopa
May 22, 2003 06:43 PM
