Car wont start need help
today i got into my car drove off for about 10 minutes then when i stop at a
light took a turn and out of no where the transmission started slipping really
bad like i was in neutral and floor gas so i pull over came to a complete stop
then the car just shut off i try to start it again it wont start but the starter is turning but the crank is not can anybody help!
אני עומד עם ישראל
Check engine light on?
אני עומד עם ישראל
Yes it may be a stored code. You may not be able to retrieve it with a regular OBD II scanner though. Is the car running now?
No the car is still not runing Ive bougth a new starter and it still won't
start I've turn the crank pulley with a socket and ranchet and
it turns fine I also took the timing cover off to see if the belt
is broken but it's find so my guess it's something to do with
the tranny I don't want to take it to the dealer yet I still
want to keep my arms and legs lol. But anyway what do u
guys think it might be
Take the shift lock cover off and place your key in it and depress. Then move the shifter into neutral. MAKE SURE that the parking brake is engaged and you are in an open area! Now try cranking the car over and see if it turns over. If not you have to check and see whether there is the "spark" missing or the "fuel" missing.
i check the spark on every one of the coil and its find i also put in neutral and tried to
start it and it still wont start all i hear is the starter but nothing is turning i think its
the torque converter or flywheel i dont really know how the work but thats my best guest
saberlove
03-11-2021 09:29 AM
bearingman07936
01-07-2016 03:22 PM
