Car is weird
3.2Seeno
Car is weird
Hey guys!
So just last week, I was driving my car and didn't see one of those islands in the middle of the road when I was turning. I ended up going over it and i heard a scrape, It wasn't that high so I assumed it was just my front lip or something. (I'm not lowered)
Yesterday, I was driving back to my house when suddenly, my car was jerking real bad and the check engine light came on, I pulled over and as i was doing so, I noticed smoke coming from the middle of my car.
I let my car sit for a little bit, had a friend come to me so he can watch my car from behind and tell me what he sees. He said he just saw some smoke come from the middle but after like two minutes, the smoke was gone and I was driving.
Heres the weird part, when I step on it (after 3K rpm) the car starts to bog down, especially in third gear. It only does so when I am accelerating past 3k.
What do you think it could be?
Compression failure? Exhaust leak? Catalytic converter got cracked?
Yaseen Gabr (01-23-2017)
3.2Seeno
I think exhaust..
Also title should be changed to "Im weird and ran over an island, what's wrong "
3.2Seeno
We all mistakes, it's human nature
Just gotta own up to the mistake
3.2Seeno
3.2Seeno
Update:
Okay, so I took my car to O'reillys and they read the codes.
Basically, cylinders 1,2,4,5,6 are misfiring and my Map sensor threw out two codes too.
Could this just be a simple spark plug fix and my little median incident had no effect?
Also, as I was driving it to the O'reillys, it drove really well.
i think you cracked your exhaust buddy... throw it on a lift and see
Before you do any more driving check all your fluids and that they're at proper levels. Did you check for leaks immediately after that median jump? My guess is the cat took a wallop and forked your O2 sensor leading to the misfire codes. If you saw smoke I wonder if the bottom of your radiator somehow took some of that hit and dumped your coolant? Hopefully that's not the case if you've been driving around in the meantime.
