Car still won't start.
Old 01-16-2019, 08:01 PM
  #41
Received 8,711 Likes on 6,718 Posts
Originally Posted by jwoods4290
Starter was bad, replaced it, replaced positive battery cable, cleaned negative cable, Still won't crank...
Good readings from the battery and it's cables.
What kind of switch is this?
Are you saying you replaced the starter yet again?
Could be the ignition switch next if the rest check out.
Old 01-17-2019, 09:49 AM
  #42
jwoods4290's Avatar
Hey Thoi, fyi, I appreciate you responding and being so helpful. Thank you for that.
Yeah, I had to replace the start I bought from Ebay (Dbelectronics), Had it tested at advance auto, in which case failed. So I had bought a 2nd starter.
Once I replaced the clutch starter safety switch, it cranked and started for me so I said hey! Let me take a ride to autozone for some anti corrosion spray for my new battery terms. Also, had a checklight on for a hearter circuit.
Turned the car off at auto zone, went back in the car (After ordering some of my favorite italian food, nice little reward) No click, no crank AGAIN.....Spent my day off for 5 hours trying to get it started again. Used the multimeader at autozone to check for voltage battery, starter, and to test out the sensor I bought, all check out...
What else could it possibly be?
Just got it towed home literally 5 minutes ago.
Old 01-23-2019, 09:15 AM
  #43
jwoods4290's Avatar
might try and work on this today.
is it possible to have tightened the clutch interlock and safety switch too far?
Old 01-23-2019, 09:23 PM
  #44
DMZ
Head a da Family
DMZ's Avatar
I don't have a clue what to do next. Connections are good, starter connections are good, got a reading from the clutch switch.. i dont know what to do...
Have you tried replacing the + battery cable? It might be corroded internally where you can't see it. It screwed me up a couple of years ago the same way.
Old 01-28-2019, 10:18 PM
  #45
jwoods4290's Avatar
It was the ignition switch..
  #46
jwoods4290's Avatar
Thanks! Keep us posted, I'm dying to find out what it was!
Old 01-29-2019, 01:42 AM
  #47
Null and proud of it
Midnight Mystery's Avatar
Thanks for letting us know!
Old 01-29-2019, 10:25 AM
  #48
jwoods4290's Avatar
I know you specifically asked so I wanted to give you that respect especially consider the help you and thoi provided.
Well, while I did spend alot of money, at least I have alot of brand new stuff aka starter, clutch switch, interlock switch, starter relay, new battery and cables and also new ignition switch!
Old 01-29-2019, 10:31 AM
  #49
Glad you got it all sorted out
P1zzaman
01-24-2019 01:55 AM
johnle
03-13-2014 01:53 PM
BigAl3000
10-03-2012 08:08 PM
vas25tl
1G TL Problems & Fixes
24
11-10-2009 01:34 AM
Quick Reply: Car still won't start.
