car starts vibrating at 40mph
Old Sep 6, 2010 | 01:09 AM
chasingthecool's Avatar
its a very slight vibration while im going like 40mph. i have a 2008 with 29k.
Old Sep 6, 2010 | 01:48 AM
Illuminati's Avatar
When was the last time your car was aligned
Old Sep 6, 2010 | 01:52 AM
3 weeks ago
Old Sep 6, 2010 | 09:53 AM
bump
Old Sep 6, 2010 | 11:56 AM
twx's Avatar
twx
Have you done anything to your car lately? Like have you hit any bumps? Run over any animals? Or have you put in new tires?
It could be your alignment. It could be your wheels need to be balanced and rotated. That's why I ask if anything happened to your car recently.
Old Sep 6, 2010 | 12:10 PM
how much does it cost to balance the tires? and where can i go do it? discount tires?
Old Sep 6, 2010 | 12:35 PM
twx's Avatar
twx
I had the same problem with my 3G TL. I just bought it 3 weeks ago from private party seller. My vibrations/shaking kicked in after 60mph.
I have a local gas station I go to when I want to mount new tires and balance and rotate. It costs me $40 for all 3 on the TL and $48 on the RDX (they charge +$2 for rims larger than 17 inches).
Check yelp for local tire places is my suggestion. Find a place that is reliable while not hurting your wallet at the same time.
Old Sep 6, 2010 | 02:10 PM
Bucks13's Avatar
Could be what the others have said, or enevenly worn tires. A rotation/balance may help, but if they're badly worn, you may need to replace the tires....this is assuming the tires are the issue.
Old Sep 8, 2010 | 01:30 AM
can you describe how your vibrations are in your car? does your steering wheel shake?
Old Sep 8, 2010 | 07:22 PM
twx's Avatar
twx
Steering wheel vibrates when I went above 60mph or higher, like that of a cellphone on silent/vibration mode. On top of that, the steering wheel also have a shake, like almost a left, right, left, right steering by itself.
Old Sep 8, 2010 | 07:23 PM
twx's Avatar
twx
Is yours similar?
Old Sep 8, 2010 | 07:32 PM
Is yours similar?
my sterring wheel doesnt shake left and right. thats serious! lol
mines vibrations aren't quick as a cell phones but more like quick mini bumps. i can't really describe it. guess you have to drive it. but it annoys me. it doesnt do it all the time either
Old Sep 8, 2010 | 07:40 PM
libert69's Avatar
18psi
bent wheel. the smallest dent will cause vibrations no matter how many times you get the wheels balanced
Old Sep 8, 2010 | 08:22 PM
cjTL's Avatar
I'm Craig
I drove around on a cracked/slightly bent rim (f potholes) for 7 hours on the highway last weekend and the vibration was noticeable just from that.
Replaced the rim and had an alignment and the difference is so noticeable. Even before the rim was cracked there was some vibration. Now its smooth.
Old Sep 8, 2010 | 10:52 PM
twx's Avatar
twx
OH SHIIIT.
Old Sep 9, 2010 | 07:09 PM
Turbocoop's Avatar
Mine has a similar problem but I can only feel the vibration in the gas pedal which I think is weird. Ill wait and see if it goes away once I get new tires cause Ill need some soon anyway
Old Sep 9, 2010 | 10:41 PM
mang03's Avatar
WOW how deep was that pothole
Old Sep 10, 2010 | 04:56 AM
VQPower37's Avatar
wow the rim straight up cracked, not even a bend! must've been a crater in the road
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
2012wagon
Sep 29, 2015 04:21 PM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
nishant11
Sep 2, 2015 10:34 AM
