car starts itself in the ON position
Old Oct 3, 2010 | 01:30 AM
gcxandrew's Avatar
Exclamation car starts itself in the ON position
when i switch my car to ON the car will start itself as if i turned the key all the way and started it normally. this only happens sometimes and the check starting system light will turn on. the CEL has just turned on and i have no idea whats going on
https://acurazine.com/forums/showthr...ighlight=u0107
this is the closest thread i could find on the subject. my car stalled today when backing out of my driveway as well. can anyone confirm its a bad battery? this happend last week too but the CEL turned itself off and the dealer said it was fine.. please help
Old Oct 3, 2010 | 01:48 AM
SpiderX1016's Avatar
hmm, maybe bad ignition switch or shorted wires.
Old Oct 3, 2010 | 02:14 AM
nfnsquared's Avatar
This should be posted in the "Problems" forum instead of here....
Did you get the codes read this time? There is a reason you're getting the CEL and the codes help tell the story....
Honestly, sounds like you have multiple problems that need to be addressed by a dealer. Time for another trip to the dealer:
https://acurazine.com/forums/3g-tl-problems-fixes-114/help-my-car-limp-mode-793127/
Old Oct 3, 2010 | 02:55 AM
gcxandrew's Avatar
https://acurazine.com/forums/showthread.php?t=793127
I know I think all the problems are from the same source though. my car is normal now there's no cel or starting problems.. the dealer wouldnt help me unless the cel is on last time i brought it in. my car is going crazy I swear
Old Oct 3, 2010 | 08:12 AM
NAiL05's Avatar
Id go with ignition switch. There is no way your car should start in the on position. The on should be a systems check and allow you to roll your windows up and down.
Old Oct 3, 2010 | 08:19 AM
nfnsquared's Avatar
Time to get tough with the service manager. Just because the CEL is not on, doesn't mean that there's no code stored. Demand that they check your car for codes after this last incident.
Can you duplicate the ignition switch problem for the dealer?
Old Oct 3, 2010 | 08:25 AM
NAiL05's Avatar
Usually ignition switch will NOT throw a CEL. It could just be worn out or something internal failed. It happens over time.
Old Oct 3, 2010 | 02:30 PM
I hate cars's Avatar
Exactly. The ECU will only catch high level issues. Nothing like an ignition switch shorting.
Old May 24, 2018 | 09:58 AM
4drviper's Avatar
Thread revival because my car just started doing this last night
After driving for about 50 feet car stuttered and every single light on the dash flashed on and off and car shut off.
Even after I pulled the key out it tried to crank so I had to haul ass back to my place and get 10mm and undo a very hot ground cable from the battery.
This morning, at least car is okay in OFF and ACC (radio working) but still tries to crank itself to death in or past ON whether I turn all the way to START.
Got the glove box removed and have a fan blowing behind the radio so we'll see...........
Feb 25, 2020 09:57 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
2012wagon
Sep 29, 2015 04:21 PM
jordanboi
Sep 5, 2015 01:33 AM
Aug 30, 2015 02:39 PM
