car starting weird
Old Jul 14, 2010 | 12:25 AM
213swampy's Avatar
car starting weird
hey i dont know if anybody can tell me what this problem is. last night i accidently try to start the car while the car was on, then the next morning
i had a problem starting it when i turn the key it turns for a good 7 to 8 seconds then the car would start but would still have to give it some gas.
Old Jul 14, 2010 | 02:11 AM
csmeance's Avatar
I'd say check the battery normally since the acura batteries suck, but if you held the key long enough to while trying to start the car while it was on, you could have damaged the starter motor. See if it continues to happen, if yes take it to the dealer and they'll diagnose it for you.
Old Jul 14, 2010 | 01:21 PM
Majofo's Avatar
Sounds like you might have damaged the starter. I don't think it's your battery because if it was under a low voltage condition it would click and not engage the starter all together, but that's not the case. The TL is fuel injected not carburated so giving it gas doesn't do anything. If it doesn't turn over in the first 1-2 seconds, stop and try again.
You can pick up a starter at any national auto parts store for around $200 if you bring in the old one plus they're usually lifetime warrantied. Easy DIY, just something to consider if you're out of warranty and the shop wants to charge you >$500.
Old Jul 15, 2010 | 12:18 AM
AMUA6's Avatar
ScoobyZINE
Originally Posted by majofo
sounds like you might have damaged the starter. I don't think it's your battery because if it was under a low voltage condition it would click and not engage the starter all together, but that's not the case. The tl is fuel injected not carburated so giving it gas doesn't do anything. If it doesn't turn over in the first 1-2 seconds, stop and try again.
You can pick up a starter at any national auto parts store for around $200 if you bring in the old one plus they're usually lifetime warrantied. Easy diy, just something to consider if you're out of warranty and the shop wants to charge you >$500.
+1
Old Jul 16, 2010 | 12:56 AM
213swampy's Avatar
well i recently took it to a shop they were telling my its my fuel pump or my fuel pressure regulator
Feb 25, 2020 09:57 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
2012wagon
Sep 29, 2015 04:21 PM
andysinnh
Sep 5, 2015 11:38 PM
jordanboi
Sep 5, 2015 01:33 AM
