Car shutters when I shut it off?
Old May 10, 2009 | 07:10 AM
njfinest05's Avatar
Yesterday I went out to move my car and when I shut it off it kind of shuttered. So I turned it on and off a few times and it did the same thing. After driving it around the block it shut off normally, very quick & quiet. Now this morning it's doing it again. You can actually feel the car shutter or shake from the engine. I can't figure out why it's all of a sudden having an issue when I shut the car off. It starts fine, has no problems. no lights on the dash are on, nothing. Any ideas?! This never happened before and I'm a little worried.
Old May 10, 2009 | 04:21 PM
blkaspec's Avatar
Full of water...
what year car, how many miles, how many owners?
Old May 10, 2009 | 06:47 PM
njfinest05's Avatar
Its an 05. 67xxx I'm the 2nd owner
Old May 10, 2009 | 08:47 PM
Majofo's Avatar
Are you running 93 octane? when was the last time you did an oil change? I'm thinking clogged precat, vacuum leak, fouled spark plug. I'd run some fuel injector cleaner like Berryman's B-12 / Seafoam / Techroline. See if that helps.. then check for vacuum leaks. If those are negative then take it to Autozone and see if any codes pop up.. if you get any misfire codes I'd replace the plugs. Check your intake filter as well.. It could dirty & restricting warranting replacement.
Old May 10, 2009 | 10:03 PM
Bender's Avatar
your probably not letting the steam purge or coal burn out before shut off.
CHOO CHOO
sounds like maybe a tune up issue
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
jordanboi
Sep 5, 2015 01:33 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
