Car shake when i brake
Old Apr 2, 2010 | 01:24 AM
RTLNOOBIE's Avatar
Today on my way to work i notice my car acting weird when i put pressure on my break. then on a high way i was doing avg speed 60-65mph. A car in front of me slow down so i apply brake to my car then my whole car shake very bad in clude the steering wheel, but the car drive smooth steering turn fine only when i apply the brake the car shoke. After i read few post in here come to the brake roto is most cuase of this event. any advice what ealse to look for.
if the rotor the #1 cuase, what should i replace it with? oem or drill sloted rotor? or any good rotor out there that you guys common used.
i have the 04 TL base.
thanks
Old Apr 2, 2010 | 02:30 AM
03Type--S's Avatar
I would say its the Rotors, If ur Rotors haven't been turned before, you can have them shaved and that will make it like new, that will be less expensive then buying new ones, but still pretty pricey at a dealership, If you have a small shop / Buddy you could save money, had all four of mine done for $80 and was included with the labor for new pads. As far as new ones, some other members may have better advice, Aftermarket are just as good as factory, of course there are some performance ones some other members might chime in with here ...
Old Apr 2, 2010 | 02:41 AM
SpiderX1016's Avatar
Does this happen in slow speeds? mid-high speeds?
Have someone check your Runout, spec is .004 inches.
Check the thickness as well and see if there is enough rotor left to cut.
Me, I'd get new OEM or Slotted Rotors.
Old Apr 2, 2010 | 02:49 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I'd say you have warped rotors.
Old Apr 2, 2010 | 07:53 AM
RTLNOOBIE's Avatar
at about 30-40mph the steering wheels vibrate and feel a little bit of car shake.
at abut 60 the car take long to slow down then if i lightly apply the brake then if put more pressure the whole car shake.
i never got my rotor turn and so i don't know if the previous owner did or not, but it look pretty thick.
i thought so too.
well thanks guys. i will have that check out asap.
Old Apr 2, 2010 | 10:44 PM
Sounds like warped rotors to me.
Do you have to push the pedal more than once just to get them to grab?
Old Apr 2, 2010 | 11:49 PM
AMUA6's Avatar
ScoobyZINE
$10 says it's warped rotors! Take them to a machine shop and have them turned, to save lotsa $$$
Old Apr 3, 2010 | 03:05 AM
RTLNOOBIE's Avatar
No. it grab perfectly. after the fact i learned that if i apply my brake slowly and give it more time to slow down its ok. but if in an instance brake it would shake.
i purchase a new rotor already. my thought was if i would of get them turn it will get thinner and the problem would come back in the future. stealer ship quote me $145 a piece for new rotor. so i went to pep boys autos store get it for 59.99 a piece ( pro stop brand non slotted). half price off for me. now i'm just waiting for my brother in law bring me my compressor back to me.
Old Apr 3, 2010 | 07:41 AM
viciouzchi's Avatar
Patiently waiting....
Smartest choice resurfacing isnt worth it to me since im having the same problem and mine were done before so now its time and im getting new rotors and pads next weekend
Old Apr 12, 2010 | 08:25 AM
relampago2424's Avatar
Hi I have an acura tl 2004 when I brake my car shakes when I go 30 mph and I brake it shakes terrible when I go 60mph and above the shake is worse all of this is coming from the front cause I feel it ...even the streering wheel shakes aswell.... I changed both rotors , I change the brakes , I put new tires and did allinegment on it and check tire pressure I still have the same problem .......... any help or suggestion I'll appreciated thank you
Old Apr 12, 2010 | 11:55 AM
dwb993's Avatar
Torque your lug nuts to 80ft/lbs maybe?
Old Apr 13, 2010 | 09:08 AM
bigmoetl1's Avatar
wdp skyhawk
the rotors are warped most likely but i would also make sure your wheels are properly balanced.
Old Dec 2, 2022 | 09:54 PM
rukalee's Avatar
any update?
Old Dec 2, 2022 | 10:58 PM
rockstar143's Avatar
almost 13 years later?!
my guess is he sold the car...
and don't cheap out on rotors.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
nishant11
Sep 2, 2015 10:34 AM
pizokk1
Aug 31, 2015 09:20 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
