Car rattles when started after engine cold.
Hey guys I have noticed that when i first start the car and the engine is cold (5-6 hours off). It tends to rev just a bit above 1000rpm, at this point it tends to jerk a bit while in park. Once the car has warmed up all is fine. I was just wondering if this was normal. I forgot to mention that i live in Montreal, Canada tends to get pretty damn cold over night, but i park in a garage at work and i noticed it does it there as well.
P.S the jerks are not violent but can get annoying
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
yea happens to me all the time, it worried me at first, but i dont think its a biggie,
what i do think is a biggie tho is when i put my car into reverse sometimes the rattle or humm gets louder, only when cold...
any suggestions as in why? should i worry?
the car cant jerk in park. r u talkin about virbrations? then the belt tensioner is no good or pulleys they have to be checked.... what year is the car how many miles? i just had the pulleys belts pump n all that good stuff done and the car has no vibration what so ever. the tech told me a lot of 04-05 had a lot of timing belt tensioner problems that also makes a clicking noise that kinda makes u think its the valves knocking.
like tripnbeat said, the car should not jerk while in park.
My 08TLS when cold sounds like a washer and dryer rumble, but once the rpms drop below 1K, it's nice and quiet.
yea id have the belts n tensioner looked at 90% of the time they'll hve to replace it under warranty this was a big problem and probably still continues to be a problem..... but after a certain amount of miles I would think honda would want u to pay for some of it.
yup it'll do it.... the idle belt tensioner could be bad as well, the drive belt pulleys for that too, there a million possibilities a bad motor or transmission mount. a full engine bay check up is needed by acura for sure.
Mine has random misfires that make vibrations when it's cold and only when the rpms are above 1,000. It's probably due to the car running very rich to light off the cats. It's done it since new and I'm not worried. The exhaust will be slightly louder up by the convertors.
Id expect random misfires at cold start. the oil hasnt touched any component on the inside for hours..... but im assuming once its warmed up its good to go with no probs?
TSB: 07-060
Applies To: 2004-07 Acura TL (ALL)
SYMPTOM
A moan or whine is heard when turning the steering wheel when the engine is cold. There may be air bubbles or foam in the power steering reservoir. The noise usually goes away when the engine warms up.
PROBABLE CAUSE
Air enters the power steering pump through the inlet joint O-ring.
CORRECTIVE ACTION
Replace the O-ring on the power steering pump inlet joint.
PARTS INFORMATION
O-ring: P/N 91345-RDA-A01
REQUIRED MATERIALS
Acura Power Steering Fluid: P/N 08206-9002 (One container repairs about 12 vehicles.)
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 5121B5
Flat Rate Time: 0.3 hour
Failed Part: P/N 91345-PAA-A01
Defect Code: 07408
Symptom Code: 04201
Template ID: 07-060A
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Parts and Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
