Car pulls to left
Car pulls to left
I need help i have an 07 acura tls and i had tein ss on them and i thougth that was causing the problem but it wasnt it because i have now taken them off.
When going above 55MPH the car pulls to the left as soon as you let go of the steering wheel, and in order for the car to go straight you have to hold the steering wheel at an angle and ive brought the car to acura about 3 times for this same problem as they cannot diagnose it.
any thoughts would be much appreciated.
thanks
thanks
thanks for all your inputs guys appreciate it
i took it to acura today and they said my rear tires r shot from my coilovers and the alignment is whats causing the problem but i think its somethign else and i guess well see onec i get new tires and alignment done. also when im on the high way the car makes some kind of noise like a belt or something any thoughtz?
I got new tires put on today the goodyear eagle gt's
and got alignment done and the car still has the same problem..any suggestions?? and i checked i have no bent rims and all tires were balanced and alignment done
When was the last time you did your brakes.. one of your pistons might be engaging.. you may need a rebuild on one of those suckers.. check your pads for even wear.. if not.. get it checked.
What happens when you press the brakes? Does the pull go away? Does it still pull to the left? Does it pull to the right instead?
Also, can you post a pic of your alignment readings that you got from the alignment shop? If you can't post a pic, then what are the readings? Be sure to include Caster measurements.
My car was pulling to the left as well. I did an alignement which didn't help. I then did a tire rotation and it's back to normal. I know something ain't right but the rotation fixed it. I think one of the tires or wheels are jacked up.
Mugen TSX
Eastern Canada
09-02-2015 12:11 AM
