Car movement with e-brake up?
8th Gear
hey guys
i just bought a 2008 TL-S (CPO from dealer). i noticed something that i wanted to get some feedback on.
let's say i stop the car on a slight incline or downward ramp, put it in Park, lift the e-brake, and let my foot off the brake (standard parking procedure) -- is it normal that the car kinda jolts a little when i let my foot off? feels like it's setting into place.
i've owned a lot of hondas/acuras in the past, and whenever i lift the parking brake, the car shouldn't move anymore...right? or is this something new with the TL?
i know i'm lifting the handle a good distance up. i feel the resistance.
any thoughts?
any thoughts?
Do the same with it in neutral and see of the parking brake stops it. It might not be holding and rocking back onto the parking pawl.
If the brake is adjusted correctly (plenty of tension in the arm), you can try breaking in the e-brake shoes. The 5at TLs only get the brake set when the car is stationary so the brake shoes never break in. They must be broken in just like any pad or shoe for maximum holding power. Try lightly applying it for a few seconds at a time while driving. After a few applications braking power will go up a bit.
8th Gear
good idea and good test.
when in neutral, e-brake up, brake off, the car slides. it has almost no effect! that's definitely not normal IMO.
should i take it to dealer to get adjusted?
Yes, for a CPO car. Tell them you want the parking brake shoes inspected and then a full parking brake adjustment performed. Do a search for "p-brake" and/or "parking brake". The scans for adjustment procedures have been posted before.
Your Friendly Canadian
Received 1,485 Likes
You'd think that the parking brake would be one of the things that would be checked for a car to be CPO'd.
Maybe it's like IHC said and the shoes. just aren't broken in? Try taking it for another test drive and break the shoes in like he said, and then try it. The car's only 3 years old and is an AT, the parking brake's probably never been used.
I've definitely noticed the same in my car and have been meaning to offer it up to the forum for some opinion.
My e-brake sucks. It very clearly doesn't effectively keep the car from rolling if I'm on any incline of significance. My normal parking procedure is to park, put the car in nuetral, pull the ebrake, let the car "rest" on the ebrake, and then put the car in park and turn it off. But if I'm on an incline then I have no choice put to let the car "rest" in gear (park). I hope this makes sense.
However, here's my kicker. If I park on an ascending incline (where the car would roll backwards) and I set the ebrake then the car will roll. It will not stop and the ebrake doesn't effectively hold the car. It WILL hold a little bit, but not to stop it. In this situation I have no choice but to leave my car resting in gear. If I park on a descending incline (car would roll forward) and put the car in nuetral and pull the ebrake, then the car will roll just a little bit, and then catch. I know it's not the park gear catching because, obviously, I'm in nuetral. But I don't know why it would catch rolling forward and not backward. Any thoughts? Hopefully this isn't bad for my car. I don't like to leave my car resting in gear, so whenever I'm parking on a hill I try to park so the car will roll forward.
Thanks for the help.
https://acurazine.com/forums/showpos...10&postcount=2
https://acurazine.com/forums/showthr...hlight=p-brake
And here's the full scan just because I'm such a nice guy
Welcome to you new guys. Please learn to use the Search function to your advantage. Here's a couple of links you would have found had you done a search as suggested in post #4:
Interesting. I'm not really familiar with drum brake characteristics but I'm assuming it's not a problem for that to be what's holding me. I would like to know why my ebrake won't stick though. It's not a big issue for me to always park on a deline, but I would like for my ebrake to pull tight and hold the car. I know I can tighten it but I'm wondering if my ebrake pad isn't worn somehow.
I'll give that a shot. What if someone were to accidently drive with the ebrake engaged? I would imagine that would wear the pad down quickly. I bought the car used so I can't know for sure if that had been done, although I would be surprised. That's something I would think a person would notice.
If what you said doesn't work then I may try to tighten the cable.
You will get a warning on the mid when you pull the brake with it moving. There is not much pad material when new so if it does not work after a while I wouldn't do anymore. You will probably smell them when they heat up but its ok.
Legend2TL
Motorsports News
01-31-2016 09:27 AM
