Car messing up please help!
Old Feb 24, 2011 | 11:34 AM
oHsicKtL's Avatar
so i was driving this morning, and while im at a stop light, my engine light came on and my car started driving outragous. i can floor the pedal and it was incease like a fricken turtle, it feels like the car is starting in 3rd gear, which it is... it stays in 3rd gear the whole time also. i tried throwing it in s-shift and shifting up and down but it will not work. not to mention if im holding on the brakes and press on the gas, it wont accellerate. i wanted to go get the code read but it wont come on at a good time. when it does come on im at school and what i do is, i unplug the battery for a while so the engine light goes off, then it will drive normally.. does anyone have any ideas? im waiting for the light to come on at a good time to get the code.. thanks in advance im a nooobie
Old Feb 24, 2011 | 11:37 AM
so you got into your car?
Old Feb 24, 2011 | 11:38 AM
oHsicKtL's Avatar
yessir poop a lock $40, i need help with this situation, that is why my battery was not on 100%
Old Feb 24, 2011 | 12:08 PM
nfnsquared's Avatar
The CEL doesn't have to be on to read a code. The ECM will store the code in most cases. Did you have a flashing "D" along with the CEL?
Take it and get the code read for free at any auto parts store and report back.
Not sure if you've done this, but read up on the 3x3 AT fluid drain/fill procedures and 3rd/4th gear pressure switch replacement.
Old Feb 24, 2011 | 12:26 PM
Jesstzn's Avatar
Mine won't either.
Old Feb 24, 2011 | 12:54 PM
oHsicKtL's Avatar
No flashing d. And is that procedure and switch replacement mandatory?
Old Feb 24, 2011 | 01:00 PM
Bearcat94's Avatar
AZ Community Team
In some situations your car will go into "limp mode" where acceleration and rpms are limited. I can't tell from your post if you're in limp mode or not. One thing to do (obviously), is shut the car off and restart it and see if goes back to normal.
The other thing is this loose cable or wire thing you were talking about yesterday. Are sure everything is properly connected and undamaged?
Really sounds to me like a trasnmission issue, but your should have a flashing "D".
Old Feb 24, 2011 | 01:26 PM
nfnsquared's Avatar
Well, no, but.... do due diligence and read up on it. Then make your own decision.
And get the code read. That will help the most...It's hard to tell if you have a transmission issue or are in "limp mode". The code/s will help...
Old Feb 24, 2011 | 01:34 PM
oHsicKtL's Avatar
No flashing d. If. Turn car off then back on it will still do it. I have to unplug battery for fee mins for cell to go off and then it will go back to normal..I will get code after I get out of class and report back.
Old Feb 24, 2011 | 01:52 PM
nfnsquared's Avatar
Sounds like you're in limp mode. May be an APP sensor....Code will tell..
Old Feb 27, 2011 | 08:14 PM
catesbros's Avatar
So when you step on the break your car won't accelerate? Have you tried taking your foot off the break? lol sorry jk
Is this only in automatic drive or manual shift mode as well? If you put it in third, then it will take off in third and stay there. You said you are new so I have to cover the basics. Don't be offended.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
