Car idles rough/shuts off randomly
Old Apr 7, 2016 | 10:04 PM
jimmyfu's Avatar
Hey guys, 100400k miles 2005 6MT;
My car's been idling rough at red lights, and sometimes will drop RPMs and sound like it's bogging down. It'll sometimes also shut off, even when my foot is still on the clutch.
The idle will usually hover around 7-800rpm, then dip below 5 before bouncing back up. But once it dips it definitely sounds like I'm going to stall, despite being in neutral. Any idea what the cause is?
Old Apr 7, 2016 | 11:23 PM
jimmyfu's Avatar
Oh and no codes, which makes it impossible (at least for me) to diagnose
Old Apr 8, 2016 | 01:31 AM
Will Y.'s Avatar
Registered but harmless
Clogged/bad EGR valve is my guess.
Old Apr 8, 2016 | 01:35 AM
042's Avatar
042
Coil packs were the source of my misfire, but the RPM never dipped like that and the car never died.
Plugs and EGR are also good places to start looking.
Old Apr 8, 2016 | 02:43 PM
GhostTL09's Avatar
fuel pump?
Old Apr 8, 2016 | 02:44 PM
WDPanda's Avatar
Is your A/C running? How's the battery and its ground?
Old Apr 8, 2016 | 02:50 PM
jimmyfu's Avatar
I don't think it's the fuel pump; doesn't happen when the RPMs are high. Would EGR issue not throw a code?
Battery is 1 year old, ground is tight and the positive cable was replaced within the last half year as well
Old Apr 8, 2016 | 03:10 PM
4drviper's Avatar
EGR is inactive (fully closed) at idle.
Old Apr 8, 2016 | 08:18 PM
sockr1's Avatar
I had this happen before it was a carbon deposit holding open egr valve. Funny enough I had this happen again today the exact symptoms you said. I think it was the same problem but this time the carbon must have dislodged itself because it stopped dipping after 10 minutes. It takes two nuts and 10 min to open the egr up and see if a carbon rock is holding your valve open.
Old Apr 8, 2016 | 10:50 PM
Will Y.'s Avatar
It may take some time for the code to appear.
My TL had the rough low idle issue for 3-4 days of daily driving before the CEL appeared due to a bad EGR valve.
Old Apr 10, 2016 | 05:13 PM
jimmyfu's Avatar
Brought it to the family mechanic, said he didn't think there were issues with the EGR. He did say that the intake and exhaust valves needed to be adjusted though; after I got the car back there hasn't been any issue. I bought a standard motor EGR valve off amazon anyway for $60, figure if the problem starts rearing it's head again I'll just change the whole thing.
Old Apr 11, 2016 | 01:14 PM
BreezyTL's Avatar
I see you have it fixed but I had similar issues with the car wanting to stall at a red light. It ended up being my A/C compressor taking a dump on me. once it was wasted the car acted normal. replaced the compressor and no issue since.
Old Apr 11, 2016 | 05:24 PM
jimmyfu's Avatar
Interesting...did you do the replacement yourself?
Old Apr 12, 2016 | 09:34 AM
BreezyTL's Avatar
No, had my mechanic do it. Parts/Labor = $550 OTD
Old Apr 12, 2016 | 01:35 PM
truonghthe's Avatar
check your EGR and make sure its clean, if its still there then check the main relay.
Carbon Legend
Aug 5, 2016 05:21 PM
nore03
May 4, 2016 02:10 PM
Evilocity
Apr 22, 2016 09:33 AM
synth19
Mar 1, 2016 05:43 PM
