Car battery light flashing?
Old Oct 28, 2016 | 10:59 PM
Mando7600's Avatar
3rd Gear
Need help guys I was driving my Acura TL type s 08 and my battery light turned on and then turned off it usually comes on when I slow down or brake well I replaced my battery and its still doing the same thing and my alternator is about 6 months old what's the problem ??
Old Oct 28, 2016 | 11:09 PM
Check your belt tension and condition. . Was it an OEM alternator?
Old Oct 28, 2016 | 11:37 PM
WDPanda's Avatar
Aftermarket or refurbished alternators are a hit and miss. You'll have to test right away. They also tend to come with alot of faulty voltage regulators.
Old Oct 29, 2016 | 12:58 AM
champaned_out's Avatar
i replaced my alternator with an aftermarket one after the oem one died on me... my battery light always comes on between 5500k to redline
its been like that for 2+ years and hasnt caused any problems so i left it as is
Old Oct 29, 2016 | 06:44 AM
Turbonut's Avatar
Take a MM and do a quick check on the bat terminals when the car is running.
Turn on accessories and check. Should be @14 volts.
Old Oct 29, 2016 | 07:41 PM
WDPanda's Avatar
Lmao that's like a shift light.
Old Oct 30, 2016 | 09:42 AM
Mando7600's Avatar
3rd Gear
Well the terminals are good and clean and the alternator connections are good as well but yeah it was a remanufatored alternator I'm going to have to check it out but could it be a burnt fused because sometimes it comes on and sometimes it does ..I haven't seen a loss of power in the car either
Old Oct 30, 2016 | 09:50 AM
Burnt fuse wouldn't cause the light to flash once in a while. Me still thinks belt tension is loosening as you drive so the alternator stops spinning for a bit. Hence the suggestion to check the belt, could be tensioners and pulleys as well
Old Oct 30, 2016 | 10:13 AM
Mando7600's Avatar
3rd Gear
well I mean I did replace the tensioner and the belt when I did the 100,000 mile service but thanks ill take into consideration..it won't mess anything up if I leave it like that right just leave me stranded lol
Old Oct 30, 2016 | 10:39 AM
Turbonut's Avatar
Just wanted to add, quick way to check when driving, run wires from the bat terminals into the pass compartment,
hook to mm and drive. On the bat terminals, if no alligator clips available, just put the wires around/under the cable ends,
and in the pass compartment, tape to mm leads then drive.
Chances are the alt is going south.
Same as the high rpm that triggers the light, the bushes don't make contact with the rotor, so light comes on.
rahul1023
2G TSX Performance Parts & Modifications
May 3, 2017 02:26 PM
Bruce Bord
Sep 19, 2016 11:39 AM
VipStyleAcuras
ILX
53
Aug 22, 2016 11:17 PM
j_linc_03
Jul 28, 2016 04:52 PM
bpenn627
Feb 7, 2016 07:41 PM
