Capacity of fuel tank
Old Dec 24, 2012 | 07:31 AM
rpatrick34's Avatar
I recently purchased an '08 TL and since I've had it I've never been able to get more than 300 miles on what the gauge says is a full tank. Seem to be Getting good gas mileage 22-25 mpg. However when it is empty I can normally get about 13 gallons pumped back into it. The computer says I should have 430 miles til empty however I'm lucky to get like I said 300 miles before it says I need to fill up again. Anyone have any clue why??? Thanks!
Old Dec 24, 2012 | 07:50 AM
HEAVY_RL's Avatar
430 miles on 13 gallons would be 33 mpg... you are taking the computers averages to literal.
That 430 is after fill up at reset, you will never achieve that number.
Keep in mind you are working with "calculations" that will continue to change based on your driving style.
Old Dec 24, 2012 | 08:17 AM
Turbonut's Avatar
https://acurazine.com/forums/3g-tl-2004-2008-93/car-has-only-14-g-tank-554838/
Old Dec 24, 2012 | 09:29 PM
Hi speed's Avatar
runnin a little boost
The tank holds 17.1 gals. My gas light comes on with about 4 gal left in the tank, so 13 gal fill up is normal.
Old Dec 26, 2012 | 11:33 PM
rpatrick34's Avatar
I do know I would never get 430 miles or 33 mpg out of a full tank of gas. Just wondering if I had a problem or if this was a standard feature to get only 300 miles on a full tank of gas at around 22-23 mpg
Old Dec 27, 2012 | 05:38 AM
Turbonut's Avatar
EPA rated fuel mileage:
18 city
26 highway
Or if completely empty, 17.1 gallons would yield 307 miles to 444 miles depending on the driving conditions.
joflewbyu2
Aug 18, 2019 10:38 PM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
