Can someone help me identify this leak?
Old Mar 11, 2012 | 08:29 PM
tonester's Avatar
I just noticed this while under the hood today. Where is the source of this leak? It looks like it's coming from one of the hose connected to the power steering reservoir, but I can't be sure.
Old Mar 12, 2012 | 01:23 PM
SpiderX1016's Avatar
P/S Pump. Does the rest of the pump have any fluid/residue on it? Have you done the hose recall?
It looks like the top hose which goes to the steering rack.
Old Mar 12, 2012 | 02:15 PM
tonester's Avatar
yup, i did the recall awhile ago. If it's leaking at the spot where they did the recall, would they fix it again?
Old Mar 12, 2012 | 02:56 PM
Nah, go to the dealer and buy the O-Ring under that hose. Just remove those two 10mm bolts, pull the hose out and change the O-Ring. Then clean it up, that should fix the leak.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
