A/C unit doesn't work.. blower can't be turned off
Old Apr 22, 2019 | 09:35 PM
aureustgo's Avatar
7th Gear
I've done a thread search, and didn't see anyone with this specific issue.
I changed out the dash and, upon reinstall, the A/C unit doesn't turn on, although the fan blower blows constantly (typically cycling from low heat to high heat, and then back again). I also installed LED lights on the dash and the climate control unit.
Fuses inside cabin and under hood are fine (and have swapped them).
Stereo works fine.
Since the stereo isn't affected by the reinstall, could I surmise it was the LED lights that are causing the issues? (I'm swapping them out tomorrow). I didn't think this was possible. If so, would that mean too much or too little current would then go through my climate control? I.e., is it just underpowered or fried?
If it's not the LED lights, would a broken wire inside the connectors cause this kind of malfunction? I didn't see any lose wires or wires being wrongly grounded (but that could be still the case). If the blower functions, does that mean the unit is receiving power? Do you recommend replacing the unit just in case to rule that out?
Old Apr 22, 2019 | 09:37 PM
Ken1997TL's Avatar
Have you tried the blower relay?
Old Apr 23, 2019 | 10:23 AM
aureustgo's Avatar
7th Gear
Since the blower turns on, I don't think it would be the relay? I'm not sure how that would make the entire climate control unit dark/non-functioning.
Old Apr 23, 2019 | 12:43 PM
peter6's Avatar
So display for the climate control is completely dark? If climate control is disconnected, blower motor will run on full by default. Think about what you did and if you did connect everything back. I would also inspect the connectors, as maybe one pin in bent in the unit, or maybe one pin slipped out from the plug. And check fuses with test light. Sometimes it's really hard to see if fuse is blown.
Old Apr 23, 2019 | 03:51 PM
aureustgo's Avatar
7th Gear
Thanks. I'll try that.
Could the (new) LED lights have any effect on the climate control working?
Old Apr 24, 2019 | 08:52 PM
WDPanda's Avatar
You must have left one of the connectors off for the HVAC
Old Apr 24, 2019 | 11:32 PM
aureustgo's Avatar
7th Gear
Thanks for the feedback but it looks like I'll have to hire an electrician. Ick.
Old Jun 20, 2019 | 11:38 AM
aureustgo's Avatar
7th Gear
Just to update:
First trip to Acura: According to Acura, if the blower runs at full, this doesn't necessarily mean hvac unit is not getting power but rather due to faulty hvac... I don't think this is true
Second trip to Acura: It turned out a connection behind the blower was loose, causing hvac unit not to work
Old Jun 20, 2019 | 12:45 PM
very cool, I learned something new today.
gilgameshx
30
Nov 21, 2014 07:06 AM
asoubliere
1/2G MDX (2001-2013)
Jul 25, 2011 01:43 PM
dannheisser
Mar 30, 2010 07:46 PM
GreenTL99
Feb 18, 2006 06:43 PM
scotty
Sep 4, 2005 08:42 PM
