Broken drivers door handle...
Yeah so last night I go to get out of my car and the inside handle didn't open my door. I now have to open the window to open my driver door. Has anyone else had a problem similar to this? Or know a fix?
Yeah man you'll see it when you remove the panel, the rods running accross behind the panel. Just be careful not to pull the panel off the door-shell, then drop it; as everything will still be connected I think there is something in the 3G Garage about how to remove it :idk:
When you take your door panel off you will see a cable with a green peice of plastic. Chances are that green piece is broken. I broke the one in my car when I was changing my speakers. I fixed it by holding the green piece together with duck tape. I put enough so that it will fit snug in the small bracket that holds it in place. Hope this helped. Oh yea I do plan on eventually replacing the cable but my fix has worked for a while now, fingers crossed. The panel has four screws, two behing the handle, one under the arm rest and one in the bottom left corner.
rockyboy
08-04-2024 10:35 AM
tman570
06-11-2019 07:56 AM
BoricuaTL
04-08-2016 01:08 PM
