Broken bolt removal tips
Old Jan 14, 2016 | 09:43 AM
charmer37's Avatar
Question Broken bolt removal tips
Hello,
I have a 2006 Acura Tl and i wanted to know what is the best method to extract a broken bolt? What i need to remove is the top bolt that connects the engine side bracket to the side engine mount....Thank You.
Old Jan 14, 2016 | 09:45 AM
Sears.com
Get one of the screw extractor/bolt extractor tools and go to town.
Old Jan 14, 2016 | 10:15 AM
charmer37's Avatar
ok, I'll check it out...Thanks.
Old Jan 16, 2016 | 06:02 PM
YeuEmMaiMai's Avatar
if you have enough room weld a nut to it
Old Jan 27, 2016 | 01:01 PM
Chad05TL's Avatar
I use a drill and then an easy-out. But it depends on how big the bolt is. And if u have enough room to position the drill so that it goes straight into the bolt without hitting the threads. You have to use a smaller drill bit of course
Old Feb 3, 2016 | 11:38 PM
Fogz's Avatar
7th Gear
I have the same issue @charmer37 but mine is in the license plate bolts. I bought a cheap $3 kit from Autozone, but haven't tried it out yet. Anyluck with another method?
Old Feb 7, 2016 | 10:13 AM
stegey's Avatar
if it is not crossthreaded a GOOD left hand drill bit will sometimes pull them out as you are drilling. a cheap left hand drill bit will not last long and get dull very quick and no way to sharpen them that i have found. a regular drill bit will do the same thing but it is going to try to screw it in farther untill the bolt bottoms out. if it is a big enough bolt i have had luck with a sharp air hammer bit and air hammer to get it started loosening then pliers or vise grips to finish it off.
biker
Oct 9, 2025 02:07 PM
