Brakes squealing after heating up
Just put brand new rotors and pads on my wife's car. It's a 6MT TL - Brambo brakes on the front. I used Centric rotors and Hawk ceramic pads.
After completing the job, took it out for a spin to bed the brakes in - and everything looked fine. The next day wife calls me and says brakes are squealing like dinosaurs in heat. Indeed, she drives home, and I can hear the car a mile away.
I take out the pads, put a generous coat of brake grease between the pads and the shims and assemble the brakes back. Take it out for a spin - and again everything is fine. Then I try a second loop, and by now the brakes heated up, and if I apply light pressure - they do start squealing!
I thought maybe the pads glazed over, so I give it a few runs with decent braking pressure, and the squealing subsides somewhat, but it's still there - especially when braking lightly.
What do I do now?
Thanks.
What do I do now?
Thanks.
KICKED IN THE BALLS
What do I do now?
Thanks.
What do I do now?
Thanks.
You need to bed those Hawk pads in... do several stops .. 40-5, 60-10, 80-40 to get them to bite & bed properly.. it may help.
.. but if they're squealing while driving you need to find the culprit and make sure they are seated properly.. make sure you bought the right stuff as well, check to see if the car pulls while braking, if so, check to see if one of the pistons is locked / needs to be rebuilt.
for the front rotors, did you get this part #
CE120.40062
Manuf. Part # 120.40062
CE120.40062
KICKED IN THE BALLS
^ damn.. totally missed that.. sounds like something is definitely awry..
Just to make it clear: the brakes make no sound while not applied. So, driving is smooth. The brakes do a terrific job of braking. It's just that they squeal upon light application when they heat up. No squealing when brakes are cold no matter how light you press.
wut.
Same with my Wilwood BBKs. I haven't found the answer I'm looking for though.
Mine also squeal when light pressure is applied. They start squealing around 40 mph until I stop. If I brake hard this doesn't happen. The dealer couldn't figure it out and they said I have plenty of pad left. Very annoying.
runnin a little boost
What do I do now?
Thanks.
What do I do now?
Thanks.
I have Rotora Ceramic pads that squeek sometimes but, braking harder makes this go away. This is the trade off you get for hi performance low dusting pads. OEM pads would solve this problem with little performance loss and alot more dust.
