Brakes
Old Jun 18, 2013 | 11:59 AM
AcuraCake's Avatar
Brakes
Hi guys, I've started to notice a noise coming from the passenger side that sounds like something from the wheels. The sound is like a worn out pad that sounds every rotation of the wheels(you know what I mean?). It can only be heard if I'm driving next to a wall or close to a curb or something and I can't hear it when I go faster than 30 or so or really slow too.
I looked at my rear passenger rotor and it is hard to turn it when I get to a certain point, then gets easier until I get to the same point. So I checked to pads and the inside pad was worn on an angle and almost completely worn so I replaced them yet the noise is still there. I was thinking it's either a sticking caliper or warped rotor. I also went out today to look at the rotors again and I saw some scratches on the rear passenger rotor. I could feel that the scratches go into the rotor so it's not just a mark.
Any input would be appreciated, thanks!
Old Jun 18, 2013 | 04:47 PM
Vlad_Type_S's Avatar
Registered Bike Offender
I think that if the caliper was sticking, you would get a constant resistance throughout the entire rotation of the rotor assuming you performed the test with the wheel still attached. Leaving the wheel on ensures the rotor is secured against the wheel hub. If you didn't do it with the wheel on, try that and see if it still resists only at a certain point during the rotation. If it does, then I think your suspicion of a warped rotor is a good place to check next.
Old Jun 19, 2013 | 08:04 AM
Project_CLean's Avatar
MMkay.
My guess:warped rotor or slightly bent backing plate (metal shield behind rotors).
Old Jun 19, 2013 | 05:12 PM
AcuraCake's Avatar
It ended up being the hand brake. I loosened it up a bit and the rotor spins fine and no noise while driving.
Old Jun 19, 2013 | 05:33 PM
Ha! That's way better than a warped rotor.
Old Jun 20, 2013 | 07:40 AM
MMkay.
So you were driving around with your handbrake up?
Or you just loosened the tension? These are self adjusting,so the sound you heard will probably come back. Maybe the inner drums are rusted up,or the shoes.
Old Jul 9, 2013 | 03:52 PM
AcuraCake's Avatar
Well, you were right. It is the backing plate. Any idea how to adjust it so it doesn't rub the rotor? Thanks
Old Jul 9, 2013 | 04:46 PM
swoosh's Avatar
takin care of Business in
lol....
you did loosen the handbrake from under the center console right?
Old Jul 9, 2013 | 05:04 PM
AcuraCake's Avatar
Yes, I didn't just lower the handle haha, but that fixed it temporarily. I just got an alignment and they said that the backing plate was rubbing the rotor. Is the backing plate the same thing as the dust shield or no?
Old Jul 9, 2013 | 05:06 PM
^yes. heatshield/dustshield/backingplate. same thing.
all you have to do is BEND it to where its not hitting anything
Old Jul 9, 2013 | 05:10 PM
swoosh's Avatar
^^^ THIS
is is very easily bend-able....
Old Jul 9, 2013 | 05:13 PM
^might take multiple tries, as its a circular disc thing.....so if you bend the top part upwards, the bottom will try to come up and hit the rotor.
its not needed, so, if you can, I'd just remove it.
Old Jul 9, 2013 | 05:16 PM
swoosh's Avatar
^^^ THIS
again
Old Jul 9, 2013 | 05:27 PM
AcuraCake's Avatar
Thanks guys. Sorry for the newbness, just wanna be prepared before I look at it for the 10th time lol.
Old Jul 9, 2013 | 05:38 PM
last weekend, I helped tldude with replacing his driverside axle.
in the process, i bent the heat shield.
we replaced the axle and went for a test drive.
a horrible noise emitted.
after doing the axle, I just wanted it to be done with.
but nope, we had to look for the noise.
had to jack it back up several times before we found the culprit.
we bent it one way and thought it was all clear.
put the wheel back on and lowered it.
test drove it.
the heat shield was still hitting the rotor!!!!!!
ahhhh!
we finally got it after like 50 million times...
here's some eyecandy from sunday.
Old Jul 9, 2013 | 05:48 PM
AcuraCake's Avatar
Haha, that sounds like my last week. Installed coilovers - took 2 days lol, installed ingalls rear camber kit - took 2 hours after figuring out I had to buy new nuts/bolts and had to sawzall 2 bolts out (fun stuff lol), had to tighten rear end link twice because of clunking, and my brake noise that's been going on for a while. Damn.
Can't wait to start this mission now haha.
Old Jul 9, 2013 | 05:51 PM
swoosh's Avatar
wouldnt the best way to do it will be rotate the wheel with the car jacked up and look for rubbing?
its never ending!
lol but i'm on a quest for perfection!
Old Jul 9, 2013 | 05:52 PM
yep, thats exactly what we did.
(i was exaggerating in my story a little bit)
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
