Brake wear pattern not the same after pad/rotor replacement
Old Jun 11, 2015 | 12:01 AM
polish_pat's Avatar
I just replaced my front pads and rotors. I greased up pretty much anything i could...but i'm not sure if the pad wear pattern on rotor is normal.
Before, there was a wear mark in the middle of the rotor leaving a thin band on top and below where the pad was not making contact, now it seems as there is only a band below and the pad makes contact with all the rest of the rotor. This is on both sides. Is this because i bought performance breaks?
As you can see in the image below:
Old Jun 11, 2015 | 06:17 AM
Turbonut's Avatar
Pull the caliper and see where the rotor is making contact with the pads, then go from there.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
gqdabien
Sep 8, 2015 11:41 PM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
