Brake Refinishing
Old Nov 20, 2007 | 09:34 AM
hondasaurus's Avatar
Brake Refinishing
After reading the TSB on refinishing 6MT brake discs, would nondealer brake shops have the same type of equipment to conduct "on car lathe" refinishing?
This is a required method as stated in the TSB.
Old Nov 20, 2007 | 10:18 AM
Crysophylos's Avatar
I could be wrong, but isn't this a fancy term for "turning" or "resurfacing" the rotors - a necessary step in ANY BRAKE JOB!! I think this "on car lathe" is simply a machine that doesn't require the added step of removing the rotors to be resurfaced. Instead, it does it while the rotors are on the car.
Could you post a link the the TSB?
Old Nov 20, 2007 | 01:05 PM
http://www.in.honda.com/Rjanisis/pubs/SB/B04-019.PDF
http://www.in.honda.com/Rjanisis/pubs/SB/B00-037.PDF
also can be found here:
https://acurazine.com/forums/showthread.php?t=154245
Old Nov 20, 2007 | 08:03 PM
01tl4tl's Avatar
the on car system is a specialty tool- call each shop and ask if they have one
It cuts the rotors straight with the hub as it rotates under engine power-
not just smoothing it to its own rotation- making it a unit with the driveline
result is smoother braking in cars with known touchy rotors
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
