brake pad recall on 06 tl 5at
hello, on a recent dealer service they replaced the rear brake pads and turned the rotors claiming a recall on pads only. does anyone know of thsi recall and should acura have replaced the rotors instead of turning them?
I would be interested in knowing as well. I had my rear pads done at the dealer recently as well...he said he was only going to charge me for pads...no labor. Which I thought was a very nice thing to do...however if there was a tsb or recall it wasnt so nice as they would be charging me for something that should be free.
AZ Community Team
Received 7,771 Likes
Recall? No.
You can look up all recalls here:
http://www-odi.nhtsa.dot.gov/
ALSO, recalls for your vehicle should be listed at www.myacura.com. Sign up if you're not registrered.
TSB? Maybe. Check here:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
But as far as I can recall, no TSB for what you describe.
This is as close as I can find regarding pads, but it's for Brembo fronts:
TSB 04-019: Brembo Brakes Squeal With Light Application.
http://www.in.honda.com/Rjanisis/pubs/SB/B04-019.PDF
