Brake lights won't turn off
Old Aug 25, 2020 | 07:39 AM
dannyc3.2's Avatar
I have a 05 TL and car was running good didn't notice anything until I got home, turned the car off and my brake lights are on as well as the 3rd brake light. any idea of what could've happened and how to fix?
Old Aug 25, 2020 | 07:40 AM
perhaps the brake light switch is malfunctioning
Old Aug 25, 2020 | 09:14 AM
dannyc3.2's Avatar
So do you recommend replacing the switch?
Old Aug 25, 2020 | 09:25 AM
you can test the brake light switch with a multimeter or using a test light.
if you dont have any of these tools, you could possibly buy a new switch and replace it to see...and if not, perhaps you could return the switch
Old Aug 25, 2020 | 12:10 PM
dannyc3.2's Avatar
Would there be any other reason why ?
Old Aug 25, 2020 | 12:25 PM
peter6's Avatar
Reason to test the switch? So you don't replace it for nothing.
I mean it's good to be sure that work you are doing will actually fix the problem, right?
Old Aug 25, 2020 | 01:00 PM
El_Cheapo's Avatar
It's either a bad switch or battery power is somehow now melted past the switch. It's a pretty simple circuit so you should just unplug the brake pedal position switch and see if it turns off your lights. If the lights turn off, then it's because of a bad switch.
I agree with you.
You've probably noticed that people are fast to confidently post a solution without providing any info on how to confirm it first. OPs are also happy to start throwing parts at their cars too.
Old Aug 25, 2020 | 01:12 PM
In addition, check #8 pedal stopper pad behind #6 stop & cruise switch assembly.
https://www.acuraoemparts.com/oem-pa...BlZWQtbWFudWFs
https://www.amazon.com/Dorman-74015-Brake-Pedal-Accelerator/dp/B001C6JCTQ/ref=sr_1_1?dchild=1&keywords=brake+pedal+stop+pad&qid=1598379094&sr=8-1 https://www.amazon.com/Dorman-74015-Brake-Pedal-Accelerator/dp/B001C6JCTQ/ref=sr_1_1?dchild=1&keywords=brake+pedal+stop+pad&qid=1598379094&sr=8-1
Old Aug 25, 2020 | 11:02 PM
Jackass's Avatar
Originally Posted by El_Cheapo
I chuckle every time I see this diagram due to a mistake on it. The way it is currently drawn, it would be a dead short each time the pedal is pressed. Notice that the WHT/BLK is fed from 12V+ and has a direct path to GND. The 2nd line from the left should not exist to the bottom.
Old Aug 26, 2020 | 01:43 AM
good catch!
Old Aug 26, 2020 | 07:14 AM
dannyc3.2's Avatar
that's what is was upon looking at it more i noticed a blue kind of rubberish object
Old Aug 26, 2020 | 11:13 AM
Was it the pedal stopper pad?
Old Aug 27, 2020 | 08:25 AM
dannyc3.2's Avatar
Yea quick trip to advanced and problem fixed
Old Aug 27, 2020 | 08:40 AM
Yeah, usually there is some remnant of the stopper pad on the floor somewhere. That gives it away!
Thanks for the confirmation.
Always start with the simple stuff, then work towards the more difficult.
Old Aug 27, 2020 | 12:26 PM
El_Cheapo's Avatar
so what was it? switch or stopper?
Old Aug 27, 2020 | 04:42 PM
https://www.ebay.com/itm/251125982912
zurc137
1G RDX Problems & Fixes
Jun 23, 2020 08:03 PM
cgprelude
3G RDX (2019+)
Oct 24, 2018 03:00 PM
JPerkMr954
Sep 6, 2016 12:55 PM
MOBB
Aug 3, 2007 07:40 PM
