Both headlifghts dead
Old Mar 14, 2025 | 11:49 AM
Gaspar74's Avatar
9th Gear
So Wondering if anyonew has amny tips for this. I tried the fuse and they were fine. None of the lights turn on Low or high beam. I know the cars 20 yrs old now but still love it. Someone said maytbe the whole ballast igniter etc needs replacing but thats not something i can easily do. Any other ideas?
Old Mar 14, 2025 | 07:59 PM
Jackass's Avatar
I mean, you need to do the basics. High and Low beam are the same bulb. Fuses are fine, so now you really are down to most likely swapping parts. But...if both lights died at the same time, it most likely isn't ballast, ignitor, nor bulb. It is more likely to be the switch.
Now if they "failed" at different times, that is a completely different game here. You most likely need to swap parts around to try to rule out various parts as failure points.
CL-S progression 01
May 24, 2013 06:12 PM
s2000gtx
Apr 9, 2012 07:57 AM
CHISOX1
Jun 24, 2011 06:26 PM
RRSV
2G CL Problems & Fixes
Jun 12, 2010 12:25 AM
djmanu
Jun 4, 2010 06:47 AM
