Blown head gasket or bad water pump?
Old Jun 11, 2020 | 09:22 AM
Kstep223's Avatar
Guys I need help my 07 tl type s the engine temp gauge recently starts to rise a little after i drive for about 30 minutes so i checked my coolant and its still good and my radiator fans still work i’ve noted that i have been leaking water from the passenger side a little but i think thats the AC i took it to a honda dealer and they say blown head gasket in the front and back about 2800$ I dont wanna get cheated pls help
Old Jun 11, 2020 | 09:30 AM
horseshoez's Avatar
Latent car nut
Have a cylinder leak down test performed; that'll tell you if it is a head gasket. That said, I might be inclined to swap out the thermostat and see if that fixes our issues.
Old Jun 12, 2020 | 08:55 AM
Ted Kief's Avatar
Do the leak down test I Think if the head gasket was bad you would be losing coolant
Old Jun 12, 2020 | 11:05 AM
El_Cheapo's Avatar
Take it to a indy shop to get a cheaper quote.
I recommend a compression test. It's faster than a leak down test. You can also pressurize the coolant system to try to find a leak.
acura1999tl
Jan 30, 2016 02:52 PM
Beachbound
1G TL Problems & Fixes
Mar 15, 2014 09:34 PM
LJ909
Mar 3, 2013 11:11 AM
kuckle1
Jun 22, 2012 12:45 AM
mobfigr
Sep 28, 2004 10:09 AM
