Blend door actuator location
So my air flow system seems to be stuck on the front vents no matter which vent I want it to go to.
Vacuum lines look good, so I was wondering where the location of the blend door actuator and the mode door actuator are, if available on our model TL. I just did a bunch of Googling and found nothing, plenty of location for other model vehicles though.
Seems to be the driver's side actuator. The passenger side vents still change if I want it to so that's a plus.
Could be the air mix control motor?
For some reason it started working after I took off the glove box to make sure no connectors were loose as I had replaced the cabin air filter a few weeks back. I noticed after I hate put the glove box back and went out to run some errands.
CPU ASSY., AUTO AIR CONDITIONER/HEATER UNIT for 2008 Acura TL
Its on the driver side
Not sure if that helps. I'm having troubling copying the pages from the service manual.
so far it's working though, so gonna see if that lasts.
appreciate you posting that though, I'll bookmark it for future reference.
