Best fix for headlights that is turning yellow-ish
I was trying to search through this forums, but there is wayyy too much things going on. lol
Does anyone have any input about the best way I could fix this problem? Its just the headlights are getting that yellow look when it gets older.
Heard there is ways to help make it look clearer
Any help would be appreciated, Thank you in advance
I'm pretty sure you can call a reputable detailer or shop who can buff and add a clearcoat on them to keep them from oxidizing but for a price will vary. I plan to do the exact same thing, mine are just barely on the edge of my right headlight is oxidizing(hazing yellowish) .
If you dont want to pay than there is the option of if you have the experience in using a buffer/rotary, but someone with more insight can chime in but I think there are threads on this topic. As I dont want give the wrong info.
teeeejaay (08-24-2012)
riding low and steady
http://www.walmart.com/ip/Meguiar-s-...n-Kit/16386195
http://shop.advanceautoparts.com/web...hedFrom=header
Toothpaste and a microfiber will work if your looking to spend next to nothing.
If not then get a Meguiars restoration kit it works pretty good i think it leaves a coat of clearcoat to prevent future oxidation aswell
'07 TL Type-S
I used one from Turtle Wax on my sisters Jetta and it worked great.
Former Sponsor
You can use 3M headlight restoration kit and then apply x-pel headlight film on the lenses to keep them looking new for years. If you were to JUST use any headlight restoration kit and leave the headlights as they are then they'll go yellow again in a couple of months as there is nothing protecting the lenses from UV rays.
^^^ with what you said, I used Meguiars Scratch X2.0 and it works wonders on head lights and other misc scratches on your vehicle. with head lights tho you are right, I had to do it about every 3-6 months, didnt bother me tho, pretty much just Wax on....wax off.
Coolest A-zine Member
I used the Turtle Wax kit and it looked great for awhile, but came back quickly. It includes the clear coat applicant for the end, which is a HUGE plus. Not sure why the clear didn't last longer. I think I've got larger issue on the inside on the headlights also. Too bad JNC isn't closer
This stuff is AWESOME!
I really can't put into words how much I love this product. I've been using it for about 3 years and I've done multiple cars multiple times with just one ball and one bottle of cleaner.
Here's Geetee Dan's headlights when he came to my place to clear them. Look how nasty and hazy they were:
Then I got that Mother's ball out and DID WORK...
More pictures in this album: http://flic.kr/s/aHsjB78H6s
Like I said, I love that product and would recommend it to everyone. It's super easy to use and priced very reasonably.
Your headlights are yellowing due to a failing UV protective coating.
Headlight restoration kits are a cheap and easy way to make them look clear again. Just keep in mind that these kits work by using mild abrasives to remove the oxidation, but in the process they also remove whatever UV protection that was left. This basically leaves your headlights "naked", so they will yellow up again in a few months.
I've heard people say you can apply "x, y, z" to the headlights to keep them from yellowing again, but as far as I know, none of these claims have been substantiated. Here's a good thread on the subject with some input from lighting experts: http://www.candlepowerforums.com/vb/...ns-Restoration
I use the same kit which I got at Pepboys and it works great just like you said. I also bought some liquid "Headlight Sealer" by Blue Magic (http://bluemagicusa.com/index.php/bl...c/products/238) which I applied after using the mothers kit, and it definitely helps keep them from yellowing as fast.
Thank you for the advice
Thanks for the tips on the Mothers kit. My TL stays garaged, but I bought some other product (I forget which) at the auto parts store to use on my Camry, and it sucked big time.
tman570
06-11-2019 07:56 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
