Battery light issue
Old Sep 3, 2019 | 04:14 PM
caseyjones's Avatar
Battery light issue
Hey everybody,
So I have had my Type-S for about a month now. The first week I had the car the battery light came on. I took it to Advance and had them test the battery and alternator. The battery was good, the alternator was good resting but showed low voltage under load - around 12.8 volts... So i figured I needed a new alternator. I didn't feel like messing with it right then so I have been driving it around since then with the light still on. This past weekend I figured I would finally change it out. When I went to pick up the alternator I had them test the battery and alternator again and everything was fine. So I drove across town to an Autozone and had them check it - battery and alternator good! I drove to about 4 hours to a family reunion this weekend and had it checked again up there and everything was good!
Has anyone had a similar issue? There are no signs that it could be the alternator. It runs fine, electronics are fine, starts fine, etc. Are there any fuses or anything that could be causing the light? I really don't feel like changing the alternator if I don't need to.
Old Sep 3, 2019 | 04:15 PM
could be a belt tension issue that's causing sporadic issues.
Old Sep 3, 2019 | 04:46 PM
caseyjones's Avatar
I replaced the belt tensioner last week so I would hope that's not it
Old Sep 4, 2019 | 12:56 PM
TVL65's Avatar
It could be your alternator starting to go. Keep an eye on it for sure. If the light comes back on I would change the alternator & battery at the same time. I have 164,000 miles on my 07' Type S and just waiting for that light to come on. I'm amazed the alternator hasn't gone yet.
Old Sep 5, 2019 | 10:02 AM
caseyjones's Avatar
Well the light has actually been on this whole time, but aside the first time, each time I had the battery and alternator tested they were fine. I may just change it out just to see if that fixes it.
Old Sep 5, 2019 | 10:36 AM
I wouldn't put too much trust on the 'test' they do. I've had batteries and alternators that "test" fine but still are problematic.
Old Sep 7, 2019 | 10:02 AM
caseyjones's Avatar
Yeah you were right... I changed the alternator and the battery light went off. Thanks for the advice
Earless
1G TSX Problems & Fixes
Aug 10, 2016 07:25 PM
mattyacura
Jan 23, 2016 08:02 AM
KiTTyOnRoiDs
Jun 11, 2015 03:52 PM
supraken
May 17, 2007 11:29 AM
Stew97CL3.0
Feb 2, 2006 08:35 AM
