Battery light issue
Battery light issue
Hey everybody,
So I have had my Type-S for about a month now. The first week I had the car the battery light came on. I took it to Advance and had them test the battery and alternator. The battery was good, the alternator was good resting but showed low voltage under load - around 12.8 volts... So i figured I needed a new alternator. I didn't feel like messing with it right then so I have been driving it around since then with the light still on. This past weekend I figured I would finally change it out. When I went to pick up the alternator I had them test the battery and alternator again and everything was fine. So I drove across town to an Autozone and had them check it - battery and alternator good! I drove to about 4 hours to a family reunion this weekend and had it checked again up there and everything was good!
Has anyone had a similar issue? There are no signs that it could be the alternator. It runs fine, electronics are fine, starts fine, etc. Are there any fuses or anything that could be causing the light? I really don't feel like changing the alternator if I don't need to.
could be a belt tension issue that's causing sporadic issues.
It could be your alternator starting to go. Keep an eye on it for sure. If the light comes back on I would change the alternator & battery at the same time. I have 164,000 miles on my 07' Type S and just waiting for that light to come on. I'm amazed the alternator hasn't gone yet.
I wouldn't put too much trust on the 'test' they do. I've had batteries and alternators that "test" fine but still are problematic.
Earless
1G TSX Problems & Fixes
08-10-2016 07:25 PM
mattyacura
01-23-2016 08:02 AM
KiTTyOnRoiDs
06-11-2015 03:52 PM
