Battery Drain.
Battery Drain.
2008 TL on 3rd new battery. Drain occurs if it sits more than 24 hours. After that, it's completely dead. I did an extensive search which led to possible Bluetooth causing the drain. However, I have removed it completely and the battery drain still occurs. I have owned this car for about 3 years now, and never had an issue y til about 4 months ago. I have to keep the cat on the battery charger if it sits longer that a day. I have taken it to a local shop who tested the battery/alternator. They advised that everything is fine. Took it to another shop and they told me the same thing. Any ideas? Am I missing something?
Registered but harmless
Received 1,149 Likes
Did the shop test the drain at the fuse blocks?
Do you have any aftermarket audio, alarm, remote start or iSimple?
If yes, start with those.
A/C or other relays going bad can cause a drain as well.
Welcome to AZ.
Welcome to AZ.
Nothing aftermarket installed. Both shops said they couldn't find anything that would cause the draw.
If the shop(s) checked for a draw at the fuse blocks (not at the battery or alternator), they should be able to detect and isolate whatever is causing the draw.
Otherwise, you may have a defective battery with a dead cell.
How do you know there is a drain on the battery, as opposed to having a dying starter or bad ignition switch?
flybyglass
01-15-2016 07:00 PM
haha0002
1G RDX Problems & Fixes
01-12-2016 07:39 PM
