Battery Drain.
Old Jan 18, 2016 | 02:59 PM
Wolf Hunter's Avatar
3rd Gear
Battery Drain.
2008 TL on 3rd new battery. Drain occurs if it sits more than 24 hours. After that, it's completely dead. I did an extensive search which led to possible Bluetooth causing the drain. However, I have removed it completely and the battery drain still occurs. I have owned this car for about 3 years now, and never had an issue y til about 4 months ago. I have to keep the cat on the battery charger if it sits longer that a day. I have taken it to a local shop who tested the battery/alternator. They advised that everything is fine. Took it to another shop and they told me the same thing. Any ideas? Am I missing something?
Old Jan 18, 2016 | 04:21 PM
Will Y.'s Avatar
Registered but harmless
Did the shop test the drain at the fuse blocks?
Do you have any aftermarket audio, alarm, remote start or iSimple?
If yes, start with those.
A/C or other relays going bad can cause a drain as well.
Welcome to AZ.
Old Jan 18, 2016 | 04:51 PM
3rd Gear
Welcome to AZ.
Nothing aftermarket installed. Both shops said they couldn't find anything that would cause the draw.
Old Jan 18, 2016 | 06:50 PM
Will Y.'s Avatar
How do you know there is a drain on the battery, as opposed to having a dying starter or bad ignition switch?
If the shop(s) checked for a draw at the fuse blocks (not at the battery or alternator), they should be able to detect and isolate whatever is causing the draw.
Otherwise, you may have a defective battery with a dead cell.
Old Jan 18, 2016 | 09:22 PM
3rd Gear
Yeah I'm not sure how or what they exactly checked. I know the battery isn't bad since I'm on my 3rd one in 4 months. That what both shops (including) Acura kept telling was the issue.
Old Jan 19, 2016 | 03:25 PM
Jonney07's Avatar
Are you sure they checked out the alternator correctly. maybe try one more shop and see what they say.
Old Jan 19, 2016 | 03:59 PM
TLer trash's Avatar
I have heard of at least two people who mistakenly disconnected the sunroof/courtesy light module, thinking it was the HFL module.
johnma
Jan 27, 2016 12:17 PM
Kaputnik
1G RDX (2007-2012)
Jan 18, 2016 04:48 PM
Alex Gonzalez
Jan 15, 2016 11:42 PM
flybyglass
Jan 15, 2016 07:00 PM
haha0002
1G RDX Problems & Fixes
Jan 12, 2016 07:39 PM
