Battery Died. Why?
Old Sep 6, 2006 | 12:40 AM
Riu's Avatar
Riu
2004 TL
Battery Died. Why?
Car sometimes takes a extra second to start but this time i got in the car and it started but made a weird noise. Turned car off and tried to put it back on and no go. Dead. I get a jump and i drive somewhere and leave car on and come back. Turn car off and back on and it takes 5 seconds to start. The next time it was dead.
I bought a new cell phone car charger today. It has been plugged in but it has a light and the light goes off when the car is off. I unplugged it now and plan on getting a jump and heading to the acura dealer tomorrow. What do you think?
Old Sep 6, 2006 | 06:28 AM
trancemission's Avatar
Regions Leader
2004? maybe time for new one
Old Sep 6, 2006 | 10:55 AM
davenlei's Avatar
Do you get the three dashes where your outside temp should display? If so, there is a TSB on it. If not, it may be that one of the electronic components in your vehicle is not going to sleep when you turn your car off. I had that problem on my 2006 and it was the handsfree unit. It would drain my battery. They replaced it and all is well now. BTW hope you car is still under warranty. The hands free unit was almost $500.
Old Sep 6, 2006 | 01:01 PM
Will Y.'s Avatar
Registered but harmless
I seem to recall a thread within the last 2 months or so about some defective '04 batteries as well which were covered under the warranty; I don't recall if a TSB addressing batteries alone was sent out.
Car batteries usually last at least the 4-7 year battery warranty period, and most of mine have gone 2+ years beyond warranty, excepting one not-so-"DieHard."
Old Sep 6, 2006 | 02:14 PM
berzerker's Avatar
Unshunned
similar thing happened to me on my 2k4. I left the trunk open for an hour the other day, battery died...weird, but jumped right off. Later, it started up multiple times for my wife with no issue. Later that day, we go to start it - dead..completely. Lights are so low they are flickering at 1/2 a candle's brightness. I measured it with a cheapy meter and it said 5volts. I trickle charged it for several hours with no change from the 5 volts. I finally gave up and I ended up just buying a new one
weird thing is, I don't use the HFL (it's set up, but never used) and I don't have Navi, which is what all the TSB's point to as the culprit for battery drain. I guess I had a bad battery if it wouldn't hold a charge at all.
Old Sep 6, 2006 | 03:08 PM
Riu's Avatar
Riu
2004 TL
Well. afte i got back as i said it still would not start. I unplugged the car charger for my phone and went to bed. Went to sleep and woke up and tried it again. Took about 7 seconds and it barly started. I called the dealer and im going in tomorrow at 10 am. Something is wrong. Just dont know what it is.
Old Sep 6, 2006 | 09:58 PM
havokgroup's Avatar
The batteries that came in these cars suck. We change at lease 2-3 batteries a day at the shop. Contact the dealer, it should be covered under warranty.
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
steve
Sep 30, 2015 09:23 PM
mars
Sep 28, 2015 11:03 AM
jmaxima03
Sep 27, 2015 10:22 AM
