Battery cable
Old Jul 12, 2008 | 01:56 PM
bigdell215's Avatar
Battery cable
does anyone know the procedure to change the positive power cable
Old Jul 12, 2008 | 06:26 PM
01tl4tl's Avatar
disconnect the NEG cable from the battery first-- so the electricty cant arc to you!!
then follow the POS cable down to the starter and remove- should be a few clips along the way holding it in place--thats a best guess- havnt changed one on a gen3
Old Jun 5, 2011 | 04:43 PM
chapu08's Avatar
Has anyone changed a battery cable? Need to change mine and been looking for some advice. Is this a straight replacement, just removed and install the new one? This old thread its the only one I found regarding this, not much info.
Old Jun 8, 2011 | 01:42 PM
Davor519's Avatar
7th Gear
chapu08
Why are you changing the battery cable? I have hear and read on this site the OME batteries from honda are not the best. Are you having problems with yours?
Old Jun 8, 2011 | 07:38 PM
Pat04TL's Avatar
Chap,
is your cable cracked or testing at a too-high ohm resistance level with a multimeter? Years ago, I had a bad battery connection in an Explorer, but just had to spend a couple bucks to change the cable post fitting...
Old Jun 9, 2011 | 06:33 AM
johnny3's Avatar
Run your new one down & around to the starter, leave the old one where it is (unhooked of course)
Old Jun 9, 2011 | 10:52 AM
AndrewA's Avatar
The starter cable connects to 1) the positive batter post, 2) the starter, and 3) the under-hood fuse-relay box. if you can disconnect all three, you can swap it out.
Old Jun 14, 2011 | 10:40 AM
chapu08's Avatar
Originally Posted by Pat04TL
Chap,
Originally Posted by Davor519
chapu08
Sorry for not been aware of all your answers. Finally I swap the cable this past weekend. It was like AndrewA mentioned, but damn disconnect and reconnect the starter connection was a PITA, not difficult but very inaccessible bolt. Tried to remove the battery metal-base, only to realized that there are two bolts under the base out of my reach .
I was forced to change the + terminal due to a lot of rust that ended up basically breaking the cable. I replaced the terminal for a cheap one that caused me problems starting the car a couple of times. That’s why I decided to change the whole part: only $32, a lot of sweat on a 90°+ temperature + 85% RH. Thanks for your help!
Old Jun 15, 2011 | 08:23 AM
AndrewA's Avatar
where did you get the cable for $32. I also changed the pos terminal on my cable due to corrosions but I've not had any starting issues since then. When working on my car last night I noticed some corrosion coming back again.
Old Jun 15, 2011 | 09:38 AM
Pat04TL's Avatar
Glad it worked out for you eventually. Your post reminds me. I need to clean the battery terminals on all my vehicles...
Old Jun 15, 2011 | 10:55 AM
chapu08's Avatar
Here:
http://www.oemacuraparts.com/index.p...A00&make=Acura
Best price i found with great shipping price for me . Part No. is: 32410-SEP-A00
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
ValdezQ26
Oct 1, 2015 04:48 PM
steve
Sep 30, 2015 09:23 PM
mars
Sep 28, 2015 11:03 AM
