Ball joint boot
Old Jun 6, 2020 | 10:26 PM
firebolt's Avatar
Ball joint boot
Hi!
I wonder if someone has been successful with lower control arm ball joint boot replacing?
I have both boots torn and ordered new boots. I removed old one but could not install new. It does not fit. I didn't get how to do this. There is a metal ring on the bottom of the boot and the ball joint is much thicker. So I torn a new one trying to do this.
Old Jun 6, 2020 | 10:53 PM
guitarplayer16's Avatar
That's the metal collar/sleeve that came out with the ball joint. It's supposed to stay inside the control arm and can't be bought separately.
You can separate it with heat (oxy-acetylene or mapp gas), PB Blaster, and a ball joint separator tool. Expect it to shoot out once it breaks free from the ball joint.
Manual calls to replace the lower control arm if the collar comes loose but many of us are fine with just pressing it back in.
Worse case, you can remove the whole knuckle and bring it to a shop to help you out.
Old Jun 7, 2020 | 01:07 AM
firebolt's Avatar
I'm sorry, I can not get you. That is the metal collar/sleeve? What do you mean, what is the metal collar/sleeve? Are you talking about something in the picture?
And the ball joint is not a part of lower control arm. It is pressed into a knuckle.
I will try to find a video...
Old Jun 7, 2020 | 07:23 AM
Firebolt, the 'collar' is the part circled in yellow. The area highlighted in red is the ball joint with its fastener shaft. The collar (yellow) is not supposed to be on the shaft of the balljoint, as shown in your picture. The collar is supposed to remain, upon ball joint separation, in the lower control arm. That collar should be removed to easily fit your new ball joint rubbers.
Old Jun 7, 2020 | 09:09 AM
firebolt's Avatar
Wow! It's amazing explanation! Thank you, thank you, thank you!
Base2014RDX
2G RDX Problems & Fixes
Dec 5, 2018 11:56 AM
Glorygang600
Jun 13, 2017 08:14 PM
nokkieny
Aug 18, 2015 10:15 AM
elproducto
Aug 21, 2014 05:56 PM
franco838
Nov 29, 2012 01:29 PM
