Balast or Ignitor Issue
Old Jan 13, 2015 | 09:49 PM
The Sarge's Avatar
Question Balast or Ignitor Issue
My passenger side HID light quit working. It did not come back on so I assumed it was the bulb. Removed the bumper and swapped the bulb and it still did not work. Didn't have time to troubleshoot if it was the ignitor or the ballast.
Any suggestions on if its the ballast or the ignitor.
Old Jan 13, 2015 | 11:37 PM
paperboy42190's Avatar
swap each side and find out. theres no way to tell based on your symptoms. for what its worth, i've seen more ballasts die than ignitors. but...that doesnt rule out anything.
Old Jan 14, 2015 | 12:54 AM
dezymond's Avatar
Yup, no way to tell until you switch the ignitors or ballasts. I'd switch the ignitors as they're much easier to access.
Old Jan 14, 2015 | 08:25 AM
The Sarge's Avatar
Thats the next step. Now the light comes on when I turn switch on but if I turn off then back on it doesnt come back on. Just trying to troubleshoot based on what its doing until I can get bumper back off.
Old Jan 14, 2015 | 03:22 PM
actually, to swap ignitors, it requires removing the ballasts...so might as well just swap the ballasts instead. saves you 1 extra step. gonna have to remove the headlight either way
Old Jan 14, 2015 | 09:29 PM
The Sarge's Avatar
I have a spare "universal" ballast, what would I need to do to be able to test it out?
Old Jan 15, 2015 | 11:41 AM
YOu would need a 9006 input and pigtails you would connect directly to the battery's positive and negative terminals. Assuming the ballast has a D2S output, then plug in the bulb to confirm whether or not the bulb is working. If the "universal" ballast has AMP outputs, then you'll need an AMP to D2S adapter.
But by swapping the bulbs, you already concluded that the bulb isn't the culprit. The universal ballast doesn't have the same input as the OEM ballast nor does it have a similar ignitor so it doesn't help at all here :/ Looks like you can't squirm out of the hard way of testing here :/
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
