Balast or Ignitor Issue
My passenger side HID light quit working. It did not come back on so I assumed it was the bulb. Removed the bumper and swapped the bulb and it still did not work. Didn't have time to troubleshoot if it was the ignitor or the ballast.
Any suggestions on if its the ballast or the ignitor.
Thats the next step. Now the light comes on when I turn switch on but if I turn off then back on it doesnt come back on. Just trying to troubleshoot based on what its doing until I can get bumper back off.
actually, to swap ignitors, it requires removing the ballasts...so might as well just swap the ballasts instead. saves you 1 extra step. gonna have to remove the headlight either way
But by swapping the bulbs, you already concluded that the bulb isn't the culprit. The universal ballast doesn't have the same input as the OEM ballast nor does it have a similar ignitor so it doesn't help at all here :/ Looks like you can't squirm out of the hard way of testing here :/
snorf
Nov 4, 2019 06:44 AM
