Baffling mystery...2008 type-s
when i hit the brakes, i hear a grinding, growling sound, checked the pads, all look good, had a mechanic check the pads and he said they look good, the front has aftermarket drilled rotors, i cant tell if the sound is coming from the front or back, any thoughts? it seems to only happen over 40 mph but that might be because it would be more notocable.
replace your rotors
go to your nearest AutoZone and pick up a set of the Gold /Max line and be done with it.
Jackass (03-04-2020)
has your emergency brake assembly been adjusted or messed with?
https://acurazine.com/forums/3g-tl-p...cement-761003/
There are many many many options. Go look at your local auto parts stores, Rock Auto, the various Acura dealers online and local. Just make sure they give you the correct size. The Brembo equipped cars are different than the base models.
Latent car nut
badeh2
03-31-2012 08:19 PM
