Bad amp?
Old Jan 27, 2019 | 11:25 PM
Swiftkicktotheass's Avatar
6th Gear
Bad amp?
To be clear, I searched and searched on here and Google, but could not come up with a definitive answer.
I just picked up a 04 TL about a week ago. I'm having problems with the sound quality of my audio system. Only my front right speaker seems to play the loudest. The other speakers have sound coming through them, but are very low. Is that the sign of a bad amp or could it be something else? All of my settings for the system are centered.
Old Jan 28, 2019 | 01:10 AM
ifeliciano's Avatar
Not sure if this might apply or work for you, but there is a relatively cheap fix. My right channel was really low. Basically I replaced all the capacitors on the amplifier PCB with new Nichicon Audio grade capacitors.
HOW TO: OEM Audio Amp Repair - fix buzzing/noise/no volume!
Old Jan 28, 2019 | 01:58 PM
okiegman's Avatar
5th Gear
Agree with ifeliciano
Follow the instructions in the thread. I went the route to replace all the capacitors less than 1 mf with 1mf and all the ones less than 10 with 10's. Sounds a lot better.
Old Jan 28, 2019 | 02:56 PM
6th Gear
Cool. Thanks for the input guys. It's very much appreciated!
Old Jan 30, 2019 | 09:50 AM
I know you said you searched on Google but next time, add "site:acurazine.com" to your search and it will limit your searches to just AZ. It helps narrow down the search a lot and you typically get the results you're looking for.
https://www.google.com/search?q=site...hrome&ie=UTF-8
lojik
Jul 4, 2016 07:01 PM
tommyg55
Jul 1, 2013 05:20 PM
HI50
Jun 2, 2004 08:32 PM
