Backlighting issues replace one others go out
I have a 2005 Acura TL
I recently had a issue with a error on my radio that turned out to be a stuck disc in my cd changer but while I had my dash apart I changed out some of my backlighting bulbs that went out a while back. I ordered them a while back but didnt want to take it all apart until I had a reason to go in there or when I actually felt like doing all that work.
Well the cd changer issue was a great time to do that, i ordered all OEM bulbs got all the bulb numbers from the diagrams and also used the diagrams during the install to make sure the right bulbs were put in the correct area considering they all look alike so here is what happen.
Changed the one bulb that lights up the AC and Recur button and afterwards the Passenger Mode, rear heat, and defrost are not working and on the other side all are off except for driver mode controls
So basically the only ones that are on is the one I changed (AC and recur) and the driver temp mode settling
Also changed the driver heated seat controls because the back lighting didnt work now the driver works and the Passanger doesn't (backlighting)
Last thing my backlighting on the backlight dimmer button was out changed it now works fine but the Select/rest and info button doesn't work now.
Very strange thinking of buying all new bulbs for the ones that are out and just putting all in but considering they are 2.50 a pop figured I'd get some feedback before.
Ol'Dave
Sep 5, 2020 02:56 PM
cycdaniel
Dec 17, 2019 10:58 AM
