Back Up ACC
Old Jan 19, 2013 | 12:57 PM
Slick Rik's Avatar
Back Up ACC
hey guys I noticed my battery keep dying after a day or two of not driving. I had a starting issue a month ago where i replaced the starter, new battery, corroded wires, and removed the HFL. now this battery draining issue. I been testing the fuses under the hood and when i pull the "Backup ACC" fuse the tester dims. Im not clear which components is linked to the Backup ACC. help please!!
Old Jan 19, 2013 | 01:52 PM
MEKO's Avatar
HFL...Bluetooth handsfree
Does it work?
Old Jan 19, 2013 | 03:53 PM
Slick Rik's Avatar
I completely disconnected it from its circuit board. That was last month. I also disconnect where it connects by the ceiling dome light.
Old Jan 19, 2013 | 10:06 PM
makk's Avatar
Underhood fuse box has a relay for the a/c compressor clutch that burns out and sticks on. Kills the battery fast. If you pull the relay and her a click, that is the culprit. It is black and marked "omron".
Old Jan 22, 2013 | 11:59 AM
Slick Rik's Avatar
there's 3 black fuses that marks OMRON. I pulled them all but no click sound. even when testing them, my tester showed it to be good. all fuses were good except for the Back up ACC
oyayjoe
Jan 1, 2019 10:17 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Trplezero
Mar 20, 2016 04:00 PM
d.lim
Sep 15, 2015 08:54 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
