axel problem need help!!!!!
Old Oct 11, 2009 | 12:11 PM
05 TL NBP's Avatar
i have a o5 tl and wen i turn it makes a cracking noise...it sounds like the it would be the axel but does any one else have this problem?? or know why this would happen
Old Oct 11, 2009 | 04:59 PM
csmeance's Avatar
it could be a number of things such as the rack and pinon or the PS system...
Old Oct 11, 2009 | 07:16 PM
05 TL NBP's Avatar
whats the ps system???
Old Oct 11, 2009 | 08:15 PM
csmeance's Avatar
Power Steering System, such as the hoses, pump, rack and pinion, etc
Old Oct 12, 2009 | 07:20 AM
LoveMyTL-S's Avatar
Have you had the power steering recall done? If not, I'd check with your dealership to see if it's needed. The problem is the hose is faulty and leaks.
Old Oct 14, 2009 | 12:08 AM
szucceedly's Avatar
3rd Gear
sounds like a bad CV Joint...if it pops or has a cracking noise. does your car vibrate on acceleration?
Old Oct 15, 2009 | 01:21 PM
daejeong's Avatar
I have an 05 TL and having the same problem. It only occurs when the car is not moving and you have to turn the steering wheel (i.e. when parallel parking). I'm thinking its a CV joint as well, but I'm a little suspicious since the problem started occurring shortly after I got the power steering recall done.
I'm looking forward to what you find.
Old Oct 15, 2009 | 03:35 PM
wasupdog's Avatar
My Garage not
i had this problem, a cracking/creaking sound when the car was on when i was parking. it turned out to be a bad serpentine belt tensioner pulley.
try this: when you are parking the car pop the hood. leave the car in "D" and pull up the parking brake. turn the wheel while you are standing outside of the car with the window down and see where the cracking sound is coming from (make sure you pull the parking brake up hard so the car doesn't go anywhere). if it's coming from the passenger side engine block where the serpentine belt is then it's the same problem i had with the tensioner pulley.
my car didn't make the noise in "P" and it only made the noise after the car was driven and warmed up so i heard it when i was parking in my garage.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
