Auto trans shifting?
Old Aug 22, 2015 | 10:21 AM
acuraguy94's Avatar
Hi guys. Just bought a 05 TL, auto. Love the car. Has 102k miles on it. In my opinion the car shifts a bit odd. Every gear shift after 1-2 almost makes me nauseated. It shifts smooth and doesn't slip. ATF was changed religiously throughout it's life with DW1 and Z1. But when the car is shifting, it feels like someone grabs a hold of my car from the back bumper and holds it for like half a second. Gives me that weird feeling like when you land in an airplane. Is that how these cars shift?
Old Aug 22, 2015 | 11:09 AM
polobunny's Avatar
Registered Bunny
That's exactly the opposite of a shift smooth lol. Do the pressure switches as soon as possible and hope for the best.
Old Aug 22, 2015 | 09:21 PM
01acls's Avatar
OP
Change the trans fluid until it's clean... 3x3.
Replace the trans filter.
1. Try replacing the Pressure Control Solenoids A/B assy, & gasket. Clean the screen at the bottom of the three pipes & replace the 3 O-rings.
Additional parts if needed...
2. Main shaft speed sensor.
3. Counter shaft speed sensor.
4. ATF temp sensor.
Old Aug 23, 2015 | 12:50 AM
acuraguy94's Avatar
Originally Posted by 01acls
OP
4. ATF temp sensor.
Hey! Thanks so much for the suggestions! So I have done the 3x3 and the pressure switches. Shifts are way quicker but still a little off. What would be the cost of doing the solenoids at the dealer? I'm not a car dude. Main shaft speed sensor? Does that tell the trans or ECU (not sure which) how fast I'm going? Why would I replace that? Thanks so much again
Old Aug 23, 2015 | 01:05 AM
01acls's Avatar
If your trans is still missing shifts in all gears then replace Item #1 with oem solenoid.
No need to bring it to the dealership. Your regular mechanic can do or any repair shop.
Replace the trans filter with an aftermarket part.
Don't worry about the sensors for now.
Old Aug 23, 2015 | 01:19 AM
01acls's Avatar
Show the mechanic this...
Replace parts # 6, 9, & 18 (3).
# 7 is the filter & # 21 the O-ring... (aftermarket).
Old Aug 23, 2015 | 02:23 AM
YeuEmMaiMai's Avatar
you do not need to replace the solenoid pack, just remove them, clean the screens and reinstall
https://www.youtube.com/watch?v=ZbarS605YtE
02 TLs here but your car's transmission is nearly identical
SidhuSaaB
May 30, 2020 12:40 AM
Popee
Dec 20, 2015 12:08 AM
LeVeL
Oct 18, 2015 04:19 PM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
