Anyone know what these plugs are for?
I bought a 04 tl from someone who was into modifying it like it was a civic, in trying to make it look normal again I noticed some plugs were either not plugged in or modified. I wish I would have taken pics but I was in the moment of fixing and did not stop to take pics
hope I can describe it well
took off front bumper... where the hood lock is there is 2 separate plugs one has a connector on the end the other is cut
car had a annoying noise thing when u put in reverse, I noticed that the unit was under the rear decklid to the right of the sub, it had green connector which i unplugged which stopped the noise but it looked like it was a factory plug not an add on, also it was mounted on top of a plastic black box, what is the plastic box for?
rear bumper has 4 little modules that had honda on it and said up that were mounted into the bumper, factory wiring again,
also the factory trunk does not work. is there a fuse for it?
thanks i wish i had taken pics
wiring it looks like for the 4 modules, if it does have back up sensors how does it work, because when i had it hooked up all it did when i put in reverse was make an annoying high pitched sound that made me more nervous reversing then ever
when you are close to an object it should beep and speed up the closer you get. I think some of them let off one short beep when you shift into reverse at the start though. Try parking away from anything and reconnecting, then shift into reverse and back towards something like a wall.
but i think you connected something wrong(or it was wired wrong when you got it) , as the sound is only supposed to come on when you come close to something.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
