Anyone Ever Replace HID Ballast?
Old Sep 17, 2014 | 11:34 PM
Purple ashes's Avatar
Title speaks for itself.. my headlights were moist.. my bad for not sealing them right i guess but im betting its is the ballast, tomorrow im going to try a new bulb but i got a feeling in my gut it isnt goning to work.. so question is has anyone ever replaced the ballast and where did they get it, im thinking of seeing if a junkyard has it since i want to keep it oem as possible.. but if i have to ill go with an aftermarket one.. second question would i have to replace the ignitor with the ballast?
thnx..
Old Sep 17, 2014 | 11:54 PM
guitarplayer16's Avatar
Yup, a condensed headlight may burn out your ballast.
The ballast is plug and play if you get OEM.
All you do is unplug the connector attaching to the ignitor.
Most of the time the ignitor is okay, but it doesn't hurt to try things out.
Replace the bulb first, and see what happens.
When the bulb gets heavily condensated, it would fail also.
If that doesn't work, it's most likely your ballast.
The water collected inside the headlight can get into your ballast (since the ballast sits at the bottom of the headlight) and cause it to fry.
Old Sep 18, 2014 | 02:38 AM
paperboy42190's Avatar
the TL is a hard headlight to seal compared to some other cars, dont feel too bad
benny_jdm
Jan 31, 2016 06:15 AM
pozebly
Sep 23, 2015 07:30 AM
acuraST
Sep 17, 2015 02:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
voigt
Sep 2, 2015 10:44 PM
