Another transmission issue
Old Apr 7, 2016 | 12:08 AM
Devild212's Avatar
Hi I'm new to this forum but I really need some help
I've read a lot of the treads on here about slipping transmissions bit nothing seems to be close to the issue I'm having, I hope I can get some advise on what my problem may be
Car : 2006 tl 5at 130k
Problem : trans seems to slip intermittently between 2nd 3rd and 4th gear. Between 40 - 60 mph, the speed drops and the rpms seem to spike all rhe way up to about 6k
I checked my transmission fluid and it seems dirty, no burnt smell also no cel's I started doing the 3x3 flush but only did 2 so far, could it be it just needs the last drain and refill? Or could it be somthing else? Really need input on this. It's my daily driver.
Old Apr 7, 2016 | 05:54 AM
042's Avatar
042
The short answer: it needs a new transmission. If it's already slipping it's too late.
Old Apr 7, 2016 | 09:34 AM
01acls's Avatar
Replace your trans external filter.
Inspect/clean the Pressure Solenoids A/B & C's screens for debris.
You need to change 100% of the atf.
1. To purge the torque converter you need to do a series of stop n goes for the last 10 minutes before the 1x3. Do a full stop and excelerate hard enough to raise the front end for 20-30 yards. No need excelerate into second gear. Don't get crazy tho you don't want to do anymore damage.
2. Repeat and rinse until ATF is like new.
You may temporarily use Dexron III or VI.
Good luck.
Old Apr 7, 2016 | 12:26 PM
flyromeo3's Avatar
The best you can do is replace the trans fluid with Redline D4. I had the same problem as you and when I used this fluid I was able to drive the car for a few more months before I began the rebuilt.
From my experience this gave it longevity but ultimately as it is my DD but will need to be replaced/rebuilt.
Old Apr 7, 2016 | 04:00 PM
Devild212's Avatar
Well I found the issue today, the trans filter disintegrated and plugged the line up, replaced the filter with a new oem and cleaned the bolt put and it runs like a dream again! Thank you 01acls for the input and pointing me in the right direction!!
Old Apr 7, 2016 | 06:54 PM
musiclevelz5's Avatar
If your talking about the external filter, that is the tip of the iceberg. Your transmission has an internal filter and it is most likely almost all clogged up as well. When this completely clogs your line pressure is gone and you have no gears. Your best bet is to start saving up money for a rebuild down the road.
Old Apr 7, 2016 | 10:31 PM
01acls's Avatar
:gheywave::ch eers:
Evilocity
Apr 22, 2016 09:33 AM
tlbase04
Mar 29, 2016 03:16 PM
Michael Hinchey
Mar 16, 2016 01:08 PM
kchatelain778
Feb 15, 2016 03:29 AM
DJMikeT
Jan 27, 2016 12:03 AM
